2012-2015 Honda Civic Oil Filter Replacement
  1. 2012-2015 Honda Civic Oil Filter Replacement, Oil Filter: step 1, image 1 of 1
    • Misusing a car jack can cause serious injury. Please only follow this guide if you have experience working beneath vehicles.
    • Place the jack under the vehicle.
    • Be sure to line the jack up with the frame of the car.
    • After you line the jack up, raise it.
  2. 2012-2015 Honda Civic Oil Filter Replacement, Cool the Car Down: step 2, image 1 of 3 2012-2015 Honda Civic Oil Filter Replacement, Cool the Car Down: step 2, image 2 of 3 2012-2015 Honda Civic Oil Filter Replacement, Cool the Car Down: step 2, image 3 of 3
    • Open the car's hood to allow the engine to have more airflow, thus allowing it to cool off quicker.
  3. 2012-2015 Honda Civic Oil Filter Replacement, Set the Oil Pan Up: step 3, image 1 of 1
    • Once engine is cool and oil filter is ready to be changed, place oil pan under the car where the oil filter is.
  4. 2012-2015 Honda Civic Oil Filter Replacement, Remove Oil Filter: step 4, image 1 of 2 2012-2015 Honda Civic Oil Filter Replacement, Remove Oil Filter: step 4, image 2 of 2
    • The oil filter is a cylindrical object under the car.
    • Use your hand to carefully and slowly unscrew it. Once the oil starts coming out, place it into the oil pan and let the old filter sit.
  5. 2012-2015 Honda Civic Oil Filter Replacement: step 5, image 1 of 1
    • After taking out the old filter, use a finger to get some of the oil from the spillage and rub the inside of the filter.
    • Then place the oil filter back into the same spot. Screw it as hard as you can with your hand that is not too for the next time you change your oil filter.
    • This is the final step. Now just clean everything up and you are good to go.
    • Lower and remove the jack stand.
    • Let your car run for 5 minutes before you drive it. This is to let the filter get lubed up.
Finish Line
Anthony Rodarte
121 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 13
Past 30 Days: 67
All Time: 319
