2012 Hyundai Accent Oxygen Sensor Replacement
  1. 2012 Hyundai Accent Oxygen Sensor Replacement, Oxygen Sensor: step 1, image 1 of 1
    • Never work on a hot vehicle. Allow your car to cool for at least 4 hours before performing maintenance.
    • Never work on any automotive electronics without first disconnecting the negative (-) terminal.
    • Use a 10 mm wrench to loosen bolt on the battery's negative (-) cable, then slide it off the (-) negative post.
  2. 2012 Hyundai Accent Oxygen Sensor Replacement: step 2, image 1 of 3 2012 Hyundai Accent Oxygen Sensor Replacement: step 2, image 2 of 3 2012 Hyundai Accent Oxygen Sensor Replacement: step 2, image 3 of 3
    • Locate the sensor off the exhaust header and follow the wire up to the connector.
    • Some of the pieces on the top-front of the engine are sharp; be careful what you lean on.
    • Gently work the connector out of the bracket, then disconnect it by pressing the tab inward then pulling out.
    • Plastic gets brittle over time. Be gentle and go slow. If it's not coming out, take a break and come back a little later. Be patient to avoid damage.
  3. 2012 Hyundai Accent Oxygen Sensor Replacement: step 3, image 1 of 2 2012 Hyundai Accent Oxygen Sensor Replacement: step 3, image 2 of 2
    • Gently pull the wire out of its bracket.
    • It will lift out of the bracket with minimal effort.
  4. 2012 Hyundai Accent Oxygen Sensor Replacement: step 4, image 1 of 3 2012 Hyundai Accent Oxygen Sensor Replacement: step 4, image 2 of 3 2012 Hyundai Accent Oxygen Sensor Replacement: step 4, image 3 of 3
    • Place the 7/8" (22 mm) socket around the O2 sensor. Use a ratchet and 6" extension to loosen and remove the sensor.
    • Place the socket on the sensor without the ratchet in the way. Once the socket is in place, reattach the ratchet and loosen.
    • The sensor is behind the exhaust, up against the firewall. Having a headlamp, or a friend who can hold a flashlight, is a big help. The red lights in these photos are cheap magnetic lights!
  5. 2012 Hyundai Accent Oxygen Sensor Replacement: step 5, image 1 of 3 2012 Hyundai Accent Oxygen Sensor Replacement: step 5, image 2 of 3 2012 Hyundai Accent Oxygen Sensor Replacement: step 5, image 3 of 3
    • The sensor can now be unthreaded by hand.
    • When installing the new O2 sensor, if you feel extreme resistance, STOP. It means it is cross threaded. It should easily thread in by hand.
    • Use the 7/8" (22 mm) socket to tighten the sensor firmly so it doesn't loosen from vibration.
    • The last picture is what the whole sensor looks like out in the open.
  6. 2012 Hyundai Accent Oxygen Sensor Replacement: step 6, image 1 of 3 2012 Hyundai Accent Oxygen Sensor Replacement: step 6, image 2 of 3 2012 Hyundai Accent Oxygen Sensor Replacement: step 6, image 3 of 3
    • Reconnect the plug by firmly pushing the plugs together.
    • Depending on the age of the plastic, you may or may not hear a click; just follow where the two plugs meet. There should be almost no gap.
    • Push the connector back into its bracket.
    • You may need to slightly wiggle the connector as you seat it into its bracket. It will be a tight fit by design.
    • Push the wires back into the metal brackets.
  7. 2012 Hyundai Accent Oxygen Sensor Replacement: step 7, image 1 of 1
    • Reattach the negative (-) battery cable.
    • Be sure to push/seat the terminal as far down as possible before tightening the 10 mm bolt.
Your O2 sensor should be installed and good-to-go!
Jed Porter
145 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 3
Past 7 Days: 41
Past 30 Days: 189
All Time: 5,614
