2013 Acura ILX Mass Air Flow Sensor Replacement
  1. 2013 Acura ILX Mass Air Flow Sensor Replacement, Mass Air Flow Sensor: step 1, image 1 of 1
    • Disconnect the battery terminals by first loosening them with a 10 mm wrench.
    • Always remove the negative terminal first to prevent shorting to ground and possibly causing shock or even a fire.
    • Make sure the car is off and the the key is out of the ignition.
  2. 2013 Acura ILX Mass Air Flow Sensor Replacement: step 2, image 1 of 1
    • Squeeze the clip on the top side of the wiring connector and pull out to remove it.
    • Do not touch the connections with your fingers, it may bend the needles and cause malfunction.
  3. 2013 Acura ILX Mass Air Flow Sensor Replacement: step 3, image 1 of 2 2013 Acura ILX Mass Air Flow Sensor Replacement: step 3, image 2 of 2
    • With a Phillips screwdriver, unscrew the two bolts that hold the sensor in place.
    • Pull the sensor up slowly to take it out of its casing
  4. 2013 Acura ILX Mass Air Flow Sensor Replacement: step 4, image 1 of 1
    • With a cloth towel, clean the surface from any dirt or oil.
    • Try not to have anything fall into the opening where the sensor is positioned.
  5. 2013 Acura ILX Mass Air Flow Sensor Replacement: step 5, image 1 of 1
    • Insert the new sensor and secure it down using the Philips screwdriver.
  6. 2013 Acura ILX Mass Air Flow Sensor Replacement: step 6, image 1 of 2 2013 Acura ILX Mass Air Flow Sensor Replacement: step 6, image 2 of 2
    • Connect the wiring harness back on the sensor.
Your car is fixed! The new sensor will improve the performance of the vehicle.
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 9
All Time: 763
