2013 Honda Accord Headlight Replacement
  1. 2013 Honda Accord Headlight Replacement, Headlight: step 1, image 1 of 3 2013 Honda Accord Headlight Replacement, Headlight: step 1, image 2 of 3 2013 Honda Accord Headlight Replacement, Headlight: step 1, image 3 of 3
    • Turn your vehicle off and put the emergency brake on before you begin the repair.
    • Pull the tab beside the driver side footwell to release the hood.
    • Pull the tab locking the hood upwards.
    • Pull the hood up to its maximum position.
  2. 2013 Honda Accord Headlight Replacement: step 2, image 1 of 2 2013 Honda Accord Headlight Replacement: step 2, image 2 of 2
    • Attach the hood strut in its designated position.
    • The headlight bulbs can be found on the left and the right of the engine bay.
  3. 2013 Honda Accord Headlight Replacement: step 3, image 1 of 2 2013 Honda Accord Headlight Replacement: step 3, image 2 of 2
    • The bulb is located behind the headlight and to the left of the windshield washer reservoir.
  4. 2013 Honda Accord Headlight Replacement: step 4, image 1 of 2 2013 Honda Accord Headlight Replacement: step 4, image 2 of 2
    • Pull the bulb out from the socket.
    • Use a prying tool at the base of the socket to detach the bulb from the holder.
  5. 2013 Honda Accord Headlight Replacement: step 5, image 1 of 3 2013 Honda Accord Headlight Replacement: step 5, image 2 of 3 2013 Honda Accord Headlight Replacement: step 5, image 3 of 3
    • Attach the new LED bulb to the socket.
    • Don't touch the new bulb with your hands or fingers. The oil from your skin can reduce the life of the bulb or cause it to shatter.
    • Place the bulb in the holder and turn it counterclockwise.
    • Once it is firmly in place, it should not budge.
Tahsin
145 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 16
Past 30 Days: 59
All Time: 2,593
