2013 Toyota Camry Rear Brake Light Bulb Replacement
  1. 2013 Toyota Camry Rear Brake Light Bulb Replacement, Rear Brake Light Bulb Replacement: step 1, image 1 of 1
    • Be sure that your car is completely turned off.
    • Pop the trunk open.
  2. 2013 Toyota Camry Rear Brake Light Bulb Replacement: step 2, image 1 of 3 2013 Toyota Camry Rear Brake Light Bulb Replacement: step 2, image 2 of 3 2013 Toyota Camry Rear Brake Light Bulb Replacement: step 2, image 3 of 3
    • Use a spudger to pry out the two smaller fasteners inside the trunk.
    • Push on the hook fastener to remove it.
  3. 2013 Toyota Camry Rear Brake Light Bulb Replacement: step 3, image 1 of 2 2013 Toyota Camry Rear Brake Light Bulb Replacement: step 3, image 2 of 2
    • Peel back the canvas on the side where you are replacing the bulb.
    • You will begin to see the cables connected to the rear light.
  4. 2013 Toyota Camry Rear Brake Light Bulb Replacement: step 4, image 1 of 1
    • You will see three connections; a brake light, a turn signal light, and a parking light.
    • The one we will be replacing is the brake light bulb, the biggest connection of the three.
  5. 2013 Toyota Camry Rear Brake Light Bulb Replacement: step 5, image 1 of 2 2013 Toyota Camry Rear Brake Light Bulb Replacement: step 5, image 2 of 2
    • Turn the bulb counterclockwise from the outer connection portion (the black part).
    • Pull the old light bulb from its connection.
    • This may be a bit difficult to pull apart, but not tools are required.
  6. 2013 Toyota Camry Rear Brake Light Bulb Replacement: step 6, image 1 of 3 2013 Toyota Camry Rear Brake Light Bulb Replacement: step 6, image 2 of 3 2013 Toyota Camry Rear Brake Light Bulb Replacement: step 6, image 3 of 3
    • Before handling the new light bulb, wear latex gloves or something to cover your hands. Handling the bulb with bare hands will shorten the light bulb's life span.
    • Plug the new light bulb into the connection by pushing until you hear a click.
  7. 2013 Toyota Camry Rear Brake Light Bulb Replacement: step 7, image 1 of 3 2013 Toyota Camry Rear Brake Light Bulb Replacement: step 7, image 2 of 3 2013 Toyota Camry Rear Brake Light Bulb Replacement: step 7, image 3 of 3
    • Place the connection into its slot and turn it clockwise to ensure it stays in place.
    • Follow Steps 2 and 3 in reverse.
Finish Line
Chris
170 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 4
Past 7 Days: 15
Past 30 Days: 47
All Time: 966
