2014-2022 Mazda 6 Fuse Replacement
  1. 2014-2022 Mazda 6 Fuse Replacement, Car Fuse: step 1, image 1 of 2 2014-2022 Mazda 6 Fuse Replacement, Car Fuse: step 1, image 2 of 2
    • Pull the hood release, found on the left side of the driver's footwell, to unlatch the hood.
  2. 2014-2022 Mazda 6 Fuse Replacement: step 2, image 1 of 3 2014-2022 Mazda 6 Fuse Replacement: step 2, image 2 of 3 2014-2022 Mazda 6 Fuse Replacement: step 2, image 3 of 3
    • Slide the hood release found underneath the front center of the hood to the left to unlatch the hood.
    • Use your other hand to lift up the hood while holding the hood release open.
  3. 2014-2022 Mazda 6 Fuse Replacement: step 3, image 1 of 3 2014-2022 Mazda 6 Fuse Replacement: step 3, image 2 of 3 2014-2022 Mazda 6 Fuse Replacement: step 3, image 3 of 3
    • Release the hood stand from its resting spot.
    • Pivot it upwards to align with the slot located underneath the left side of the hood, indicated by the embossed arrow.
    • Carefully insert the tip of the hood prop into the slot to hold the hood up.
  4. 2014-2022 Mazda 6 Fuse Replacement: step 4, image 1 of 3 2014-2022 Mazda 6 Fuse Replacement: step 4, image 2 of 3 2014-2022 Mazda 6 Fuse Replacement: step 4, image 3 of 3
    • Make sure the engine bay is cool before proceeding.
    • On the back side of the fuse box, found on the right side of the engine bay, push the release in and lift up the cover to separate it from the base.
    • Flip the fuse box cover over to expose the fuse puller.
    • Slide the fuse puller out.
  5. 2014-2022 Mazda 6 Fuse Replacement: step 5, image 1 of 3 2014-2022 Mazda 6 Fuse Replacement: step 5, image 2 of 3 2014-2022 Mazda 6 Fuse Replacement: step 5, image 3 of 3
    • Pull on the finger slot on the back of the panel found on on the left side of the driver's footwell to remove the cover.
  6. 2014-2022 Mazda 6 Fuse Replacement: step 6, image 1 of 3 2014-2022 Mazda 6 Fuse Replacement: step 6, image 2 of 3 2014-2022 Mazda 6 Fuse Replacement: step 6, image 3 of 3
    • Place the grooves on the small end of the fuse puller around the top and bottom edges of the fuse.
    • Pinch towards the front of the fuse puller and pull straight out.
    • Continue individually pulling and reinserting fuses until you identify the blown fuse.
    • Note the location of the fuse that you are pulling. Replacing a fuse in the wrong location may cause unwanted electrical problems.
    • See step 7 for an example of a blown fuse. See step 8 for how to replace a fuse.
  7. 2014-2022 Mazda 6 Fuse Replacement: step 7, image 1 of 2 2014-2022 Mazda 6 Fuse Replacement: step 7, image 2 of 2
    • Identify the blown fuse by comparing it to a non-blown fuse.
    • A blown fuse is usually damaged along the metal, typically near the middle inside the plastic.
    • Identify the amperage designated by the number on the front of the fuse, as well as the color.
    • Use the same amperage as the blown fuse when replacing.
  8. 2014-2022 Mazda 6 Fuse Replacement: step 8, image 1 of 2 2014-2022 Mazda 6 Fuse Replacement: step 8, image 2 of 2
    • If a fuse is blown, take a new fuse with identical amperage and place it in the same location as the old one.
    • Otherwise, replace the fuse in the same location it was removed from.
    • Align the metal prongs within the correct fuse slot.
    • Use your thumb to push the fuse all the way in.
    • The horizontal orientation of the fuse does not matter (the number can be upside down).
  9. 2014-2022 Mazda 6 Fuse Replacement: step 9, image 1 of 3 2014-2022 Mazda 6 Fuse Replacement: step 9, image 2 of 3 2014-2022 Mazda 6 Fuse Replacement: step 9, image 3 of 3
    • Replace the fuse cover by first hooking the snaps into place and pushing the rest of the cover into place.
    • Replace the fuse puller on the lid of the engine bay's fuse box.
    • Replace the lid of the fuse box by first hooking the loop of the lid onto the hook on the fuse box then pushing the lid closed.
  10. 2014-2022 Mazda 6 Fuse Replacement: step 10, image 1 of 2 2014-2022 Mazda 6 Fuse Replacement: step 10, image 2 of 2
    • Remove the stand from supporting the hood.
    • The hood will need to be temporarily supported manually.
    • Place the stand in the holder to your right.
    • Drop the hood from about six inches above the engine bay in order to give it enough force to close the hatch.
    • Alternatively you can lower the hood gently until it touches the latch, then push the hood down until the hood sits flush.
    • Make sure your fingers are clear from underneath the hood to avoid injury while closing.
If you have gone through these steps and your issue hasn't been fixed, a different guide may be necessary.
Jackson Conger
181 Reputation
1 Guide authored
UC Davis, Team 2-4, Morris Spring 2023 Member of UC Davis, Team 2-4, Morris Spring 2023
UCD-MORRIS-S23S2G4
3 Members
1 Guide authored
0 Comments
Past 24 Hours: 7
Past 7 Days: 40
Past 30 Days: 143
All Time: 1,419
