2014 Subaru Forester Headlight Replacement
  1. 2014 Subaru Forester Headlight Replacement, Low-Beam Headlights: step 1, image 1 of 1
    • Make sure you have the correct replacement part. For the specified model, the H11 Headlight Bulb is the stock-standard replacement bulb (found at any automotive store).
  2. 2014 Subaru Forester Headlight Replacement: step 2, image 1 of 3 2014 Subaru Forester Headlight Replacement: step 2, image 2 of 3 2014 Subaru Forester Headlight Replacement: step 2, image 3 of 3
    • Open the hood of your car by locating and pulling the hood release found on the driver side dash just below (and to the left) of the steering wheel. Then move to the front grill of your car and pull the latch located under the Subaru symbol.
  3. 2014 Subaru Forester Headlight Replacement: step 3, image 1 of 3 2014 Subaru Forester Headlight Replacement: step 3, image 2 of 3 2014 Subaru Forester Headlight Replacement: step 3, image 3 of 3
    • Move to the side that harbors the burnt-out headlight. Locate the headlight assembly which is positioned right behind the headlight itself.
  4. 2014 Subaru Forester Headlight Replacement: step 4, image 1 of 2 2014 Subaru Forester Headlight Replacement: step 4, image 2 of 2
    • Reach inside the headlight assembly to find the base of the bulb. Push in the release tab (which is the indention found on the base below the blue tag), then move the power plug downward from the old bulb with above-moderate force.
  5. 2014 Subaru Forester Headlight Replacement: step 5, image 1 of 2 2014 Subaru Forester Headlight Replacement: step 5, image 2 of 2
    • Grab the base of the old bulb and rotate it a quarter length counterclockwise and then you will be able to pull it straight out.
2 other people completed this guide.
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 45
Past 30 Days: 150
All Time: 12,291
