2014 Subaru Impreza Hatchback Brake light Replacement
  1. 2014 Subaru Impreza Hatchback Brake light Replacement, Brake Light: step 1, image 1 of 1
    • Turn off car engine
  2. 2014 Subaru Impreza Hatchback Brake light Replacement: step 2, image 1 of 1
    • Open the trunk of the car.
  3. 2014 Subaru Impreza Hatchback Brake light Replacement: step 3, image 1 of 1
    • Unscrew the both the 2 cm Phillips #3 screws encircled in the image shown with a Phillips #3 screw driver.
    • Unscrewing them will allow you to take out the brake light.
  4. 2014 Subaru Impreza Hatchback Brake light Replacement: step 4, image 1 of 2 2014 Subaru Impreza Hatchback Brake light Replacement: step 4, image 2 of 2
    • Unscrew both the 2 cm Phillips #3 screws by turning the screwdriver counterclockwise.
  5. 2014 Subaru Impreza Hatchback Brake light Replacement: step 5, image 1 of 1
    • Gently pull the rear light straight back.
  6. 2014 Subaru Impreza Hatchback Brake light Replacement: step 6, image 1 of 1
    • Upon opening the brake light, you should see three bulbs in total.
    • The brake light is the one on the bottom.
  7. 2014 Subaru Impreza Hatchback Brake light Replacement: step 7, image 1 of 2 2014 Subaru Impreza Hatchback Brake light Replacement: step 7, image 2 of 2
    • To remove the brake light, twist the light bulb socket counterclockwise.
    • The bulb should come out as shown in the second image.
  8. 2014 Subaru Impreza Hatchback Brake light Replacement: step 8, image 1 of 1
    • To remove the bulb, gently pull out the bulb from its connector.
  9. 2014 Subaru Impreza Hatchback Brake light Replacement: step 9, image 1 of 1
    • Gently insert the new bulb into the connector.
    • Carefully insert the bulb, as the bulb is made of glass it is susceptible to breaking and cutting you if a lot of force is used to insert it in the connector.
  10. 2014 Subaru Impreza Hatchback Brake light Replacement: step 10, image 1 of 2 2014 Subaru Impreza Hatchback Brake light Replacement: step 10, image 2 of 2
    • Reinsert the bulb back into its initial position.
    • Gently twist the bulb clockwise to further tighten the bulb.
  11. 2014 Subaru Impreza Hatchback Brake light Replacement: step 11, image 1 of 1
    • Gently push the rear light cover back into its initial place.
  12. 2014 Subaru Impreza Hatchback Brake light Replacement: step 12, image 1 of 2 2014 Subaru Impreza Hatchback Brake light Replacement: step 12, image 2 of 2
    • Reattach both the 2 cm Phillips #3 screws back into their place by screwing them clockwise with your Phillips #3 screwdriver.
Finish Line
Manas Tripathi
232 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 16
Past 30 Days: 79
All Time: 1,185
