2014-Present Kia Soul Brake Light Replacement
  1. 2014-Present Kia Soul Brake Light Replacement, Brake light: step 1, image 1 of 3 2014-Present Kia Soul Brake Light Replacement, Brake light: step 1, image 2 of 3 2014-Present Kia Soul Brake Light Replacement, Brake light: step 1, image 3 of 3
    • Open the car trunk.
  2. 2014-Present Kia Soul Brake Light Replacement: step 2, image 1 of 2 2014-Present Kia Soul Brake Light Replacement: step 2, image 2 of 2
    • Use a Phillips #2 screwdriver to remove the four 20.0 mm screws from the tail light assembly.
  3. 2014-Present Kia Soul Brake Light Replacement: step 3, image 1 of 3 2014-Present Kia Soul Brake Light Replacement: step 3, image 2 of 3 2014-Present Kia Soul Brake Light Replacement: step 3, image 3 of 3
    • Pull the tail light assembly off.
    • Apply a counterclockwise motion on the tail light while you are pulling it off.
    • Do not use too much force to prevent cracking the plastic lens.
  4. 2014-Present Kia Soul Brake Light Replacement: step 4, image 1 of 3 2014-Present Kia Soul Brake Light Replacement: step 4, image 2 of 3 2014-Present Kia Soul Brake Light Replacement: step 4, image 3 of 3
    • Turn the brake light socket 1/4 counterclockwise and pull it from the tail light assembly.
    • The brake light is located at the bottom of the tail light assembly.
  5. 2014-Present Kia Soul Brake Light Replacement: step 5, image 1 of 1
    • Press the light bulb down and turn it 1/4 counterclockwise.
  6. 2014-Present Kia Soul Brake Light Replacement: step 6, image 1 of 1
    • Pull the light bulb out of the socket.
  7. 2014-Present Kia Soul Brake Light Replacement: step 7, image 1 of 3 2014-Present Kia Soul Brake Light Replacement: step 7, image 2 of 3 2014-Present Kia Soul Brake Light Replacement: step 7, image 3 of 3
    • Press the new light bulb down into the socket and turn it 1/4 clockwise direction.
    • Before performing this action make sure you properly place the light bulb into the socket.
  8. 2014-Present Kia Soul Brake Light Replacement: step 8, image 1 of 3 2014-Present Kia Soul Brake Light Replacement: step 8, image 2 of 3 2014-Present Kia Soul Brake Light Replacement: step 8, image 3 of 3
    • Follow the guide in reverse order to put the socket and the tail light assembly back.
    • Before you screw the tail light assembly back have someone press the brake paddle to see if the new light bulb turns on.
4 other people completed this guide.
Jean Guerrier
265 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 5
Past 7 Days: 28
Past 30 Days: 166
All Time: 6,088
