2015 Mini Cooper Key Fob Battery Replacement
  1. 2015 Mini Cooper Key Fob Battery Replacement, Key Fob Battery: step 1, image 1 of 2 2015 Mini Cooper Key Fob Battery Replacement, Key Fob Battery: step 1, image 2 of 2
    • Using a plastic opening tool, create leverage in the corner of the backplate.
    • Pry open the corner and move along the seam to the middle while twisting upwards to push the cover upwards.
    • Repeat on the other side.
  2. 2015 Mini Cooper Key Fob Battery Replacement: step 2, image 1 of 1
    • Insert a plastic opening tool in the notch on the front of the key fob and pry up the backplate in the center until it pops off.
    • If you hear cracking, make sure both the corners are detached.
  3. 2015 Mini Cooper Key Fob Battery Replacement: step 3, image 1 of 2 2015 Mini Cooper Key Fob Battery Replacement: step 3, image 2 of 2
    • Press the silver button on the side of the neck, and pull the key out.
    • Insert the key into the latch on the back of the battery casing, above the slot where it comes out. Pull up and out.
    • If the backing doesn't come out easily, take the key out and try again.
  4. 2015 Mini Cooper Key Fob Battery Replacement: step 4, image 1 of 1
    • Use your finger to press down and forward on the battery. It should pop out.
0 Guide Comments
Past 24 Hours: 9
Past 7 Days: 49
Past 30 Days: 190
All Time: 10,287
