2015 Toyota Highlander Cabin Air Filter Replacement
  1. 2015 Toyota Highlander Cabin Air Filter Replacement, 2015 Toyota Highlander Cabin Air Filter: step 1, image 1 of 1
    • Make sure car is off by removing key or moving it to the off position as shown.
  2. 2015 Toyota Highlander Cabin Air Filter Replacement: step 2, image 1 of 2 2015 Toyota Highlander Cabin Air Filter Replacement: step 2, image 2 of 2
    • Move to the passenger side of the car and open the passenger side door.
  3. 2015 Toyota Highlander Cabin Air Filter Replacement: step 3, image 1 of 1
    • Open and empty the glovebox.
  4. 2015 Toyota Highlander Cabin Air Filter Replacement: step 4, image 1 of 2 2015 Toyota Highlander Cabin Air Filter Replacement: step 4, image 2 of 2
    • Detach the latch at the lower right-hand side of the glovebox.
    • Pull it outwards and unclip it with your finger as shown.
  5. 2015 Toyota Highlander Cabin Air Filter Replacement: step 5, image 1 of 1
    • Push in both upper sides of the glovebox to unhook the stops.
    • This should cause the entire glovebox to come down and detach.
  6. 2015 Toyota Highlander Cabin Air Filter Replacement: step 6, image 1 of 1
    • Remove the front plastic cover as shown. Pull on both upper tabs using your fingers.
  7. 2015 Toyota Highlander Cabin Air Filter Replacement: step 7, image 1 of 1
    • Swing down the front plastic cover.
    • Unhook the tabs from both sides of the rear plastic cover and pull it out.
  8. 2015 Toyota Highlander Cabin Air Filter Replacement: step 8, image 1 of 2 2015 Toyota Highlander Cabin Air Filter Replacement: step 8, image 2 of 2
    • Remove the old cabin air filter from the vehicle.
    • Clean any debris found in the cabin air filter compartment.
  9. 2015 Toyota Highlander Cabin Air Filter Replacement: step 9, image 1 of 1
    • Insert the new cabin air filter into the compartment.
    • Be mindful of the airflow direction arrow. The airflow arrow should point upwards as shown.
Prabhmeet Brar
169 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 51
All Time: 1,213
