2016 Toyota Camry Sun Visor Replacement
  1. 2016 Toyota Camry Sun Visor Replacement, Sun Visor: step 1, image 1 of 2 2016 Toyota Camry Sun Visor Replacement, Sun Visor: step 1, image 2 of 2
    • Using your hands, remove the protective cap to make the sun visor screws visible.
  2. 2016 Toyota Camry Sun Visor Replacement: step 2, image 1 of 3 2016 Toyota Camry Sun Visor Replacement: step 2, image 2 of 3 2016 Toyota Camry Sun Visor Replacement: step 2, image 3 of 3
    • Use a Phillips #2 screwdriver or drill bit above the screws and align the drill bit to the head of the screw.
    • Gently remove the screws from their position.
  3. 2016 Toyota Camry Sun Visor Replacement: step 3, image 1 of 1
    • Detach the sun visor once all screws have been removed.
  4. 2016 Toyota Camry Sun Visor Replacement: step 4, image 1 of 2 2016 Toyota Camry Sun Visor Replacement: step 4, image 2 of 2
    • Place and hold the new sun visor.
    • Begin to drill in the same screws you removed in step 3.
    • Note: You may need assistance from a second person.
  5. 2016 Toyota Camry Sun Visor Replacement: step 5, image 1 of 1
    • Once the sun visor is secure, place the protective cap back on.
  6. 2016 Toyota Camry Sun Visor Replacement: step 6, image 1 of 2 2016 Toyota Camry Sun Visor Replacement: step 6, image 2 of 2
    • Move the sun visor into different positions to verify proper installation.
    • The sun visor should NOT feel weak or jiggle around.
Finish Line
Angel Malta
277 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 7
Past 30 Days: 39
All Time: 738
