2017-2022 Honda CR-V Reverse Light Bulb Replacement
  1. 2017-2022 Honda CR-V Reverse Light Bulb Replacement, Reverse Light Bulb: step 1, image 1 of 2 2017-2022 Honda CR-V Reverse Light Bulb Replacement, Reverse Light Bulb: step 1, image 2 of 2
    • Open the trunk.
  2. 2017-2022 Honda CR-V Reverse Light Bulb Replacement: step 2, image 1 of 1
    • Determine which bulb(s) needs to be replaced.
  3. 2017-2022 Honda CR-V Reverse Light Bulb Replacement: step 3, image 1 of 2 2017-2022 Honda CR-V Reverse Light Bulb Replacement: step 3, image 2 of 2
    • Open the panel with a flathead screwdriver.
    • If you do not have a flathead screwdriver, anything with a flat surface should work.
  4. 2017-2022 Honda CR-V Reverse Light Bulb Replacement: step 4, image 1 of 2 2017-2022 Honda CR-V Reverse Light Bulb Replacement: step 4, image 2 of 2
    • Hold down tab and remove the cable.
  5. 2017-2022 Honda CR-V Reverse Light Bulb Replacement: step 5, image 1 of 2 2017-2022 Honda CR-V Reverse Light Bulb Replacement: step 5, image 2 of 2
    • Turn the plug to the left until you hear a click.
  6. 2017-2022 Honda CR-V Reverse Light Bulb Replacement: step 6, image 1 of 1
    • Pull the socket out of its housing.
  7. 2017-2022 Honda CR-V Reverse Light Bulb Replacement: step 7, image 1 of 1
    • Take the bulb out the socket.
  8. 2017-2022 Honda CR-V Reverse Light Bulb Replacement: step 8, image 1 of 1
    • Replace the bulb.
    • Make sure you use the Hella 921TB Bulb 921 12V 16W W2.1X9.5D T5.
  9. 2017-2022 Honda CR-V Reverse Light Bulb Replacement: step 9, image 1 of 1
    • Put the plug back into its original position.
  10. 2017-2022 Honda CR-V Reverse Light Bulb Replacement: step 10, image 1 of 1
    • Turn plug to the right until secure.
  11. 2017-2022 Honda CR-V Reverse Light Bulb Replacement: step 11, image 1 of 2 2017-2022 Honda CR-V Reverse Light Bulb Replacement: step 11, image 2 of 2
    • Reinsert the cable.
  12. 2017-2022 Honda CR-V Reverse Light Bulb Replacement: step 12, image 1 of 2 2017-2022 Honda CR-V Reverse Light Bulb Replacement: step 12, image 2 of 2
    • Reinsert the panel.
This guide tells you how to replace the bulb, and how to put everything back together
Hashmat Jadoon
235 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 13
Past 30 Days: 108
All Time: 464
