2017 Toyota 4Runner Key Fob Battery Replacement
  1. 2017 Toyota 4Runner Key Fob Battery Replacement, Key Fob Battery: step 1, image 1 of 3 2017 Toyota 4Runner Key Fob Battery Replacement, Key Fob Battery: step 1, image 2 of 3 2017 Toyota 4Runner Key Fob Battery Replacement, Key Fob Battery: step 1, image 3 of 3
    • Push the side button on the key fob to release the real key from the fob.
  2. 2017 Toyota 4Runner Key Fob Battery Replacement: step 2, image 1 of 3 2017 Toyota 4Runner Key Fob Battery Replacement: step 2, image 2 of 3 2017 Toyota 4Runner Key Fob Battery Replacement: step 2, image 3 of 3
    • Insert the key into the same shaped slit at the bottom of the key fob.
    • Twist the key to the right.
    • Separate the two halves of the key fob.
  3. 2017 Toyota 4Runner Key Fob Battery Replacement: step 3, image 1 of 3 2017 Toyota 4Runner Key Fob Battery Replacement: step 3, image 2 of 3 2017 Toyota 4Runner Key Fob Battery Replacement: step 3, image 3 of 3
    • Remove the circuit board from the inside of the fob.
  4. 2017 Toyota 4Runner Key Fob Battery Replacement: step 4, image 1 of 3 2017 Toyota 4Runner Key Fob Battery Replacement: step 4, image 2 of 3 2017 Toyota 4Runner Key Fob Battery Replacement: step 4, image 3 of 3
    • Remove the battery gently with a nylon spudger.
    • Make sure you don't damage any of the three tabs that hold the battery in place.
  5. 2017 Toyota 4Runner Key Fob Battery Replacement: step 5, image 1 of 3 2017 Toyota 4Runner Key Fob Battery Replacement: step 5, image 2 of 3 2017 Toyota 4Runner Key Fob Battery Replacement: step 5, image 3 of 3
    • Place a new battery gently back into the circuit board with the positive side of the battery facing up.
    • Make sure the tabs click into place.
  6. 2017 Toyota 4Runner Key Fob Battery Replacement: step 6, image 1 of 3 2017 Toyota 4Runner Key Fob Battery Replacement: step 6, image 2 of 3 2017 Toyota 4Runner Key Fob Battery Replacement: step 6, image 3 of 3
    • Align the circuit board with the base of the fob case and gently press it back into place.
  7. 2017 Toyota 4Runner Key Fob Battery Replacement: step 7, image 1 of 3 2017 Toyota 4Runner Key Fob Battery Replacement: step 7, image 2 of 3 2017 Toyota 4Runner Key Fob Battery Replacement: step 7, image 3 of 3
    • Align the top and base of the fob and snap it back into place.
  8. 2017 Toyota 4Runner Key Fob Battery Replacement: step 8, image 1 of 3 2017 Toyota 4Runner Key Fob Battery Replacement: step 8, image 2 of 3 2017 Toyota 4Runner Key Fob Battery Replacement: step 8, image 3 of 3
    • Insert the key back into the fob.
Finish Line
Nic
181 Reputation
1 Guide authored
1 Guide Comment
Do you know how to fix a broken key fob that doesn’t work?
Jessica Daigle - Reply Share
Past 24 Hours: 1
Past 7 Days: 13
Past 30 Days: 58
All Time: 3,731
