2019 Honda Civic Spark Plugs Replacement
  1. 2019 Honda Civic Spark Plugs Replacement, Spark Plugs: step 1, image 1 of 2 2019 Honda Civic Spark Plugs Replacement, Spark Plugs: step 1, image 2 of 2
    • Use a wrench to remove the bolts on the top of the engine cover.
    • Remove the engine cover.
  2. 2019 Honda Civic Spark Plugs Replacement: step 2, image 1 of 3 2019 Honda Civic Spark Plugs Replacement: step 2, image 2 of 3 2019 Honda Civic Spark Plugs Replacement: step 2, image 3 of 3
    • Detach the clamps of the wire holder to disconnect it.
    • Put a screwdriver under the small panel on the wire connector and lift the panel.
    • Separate the cable from the wire connector.
  3. 2019 Honda Civic Spark Plugs Replacement: step 3, image 1 of 2 2019 Honda Civic Spark Plugs Replacement: step 3, image 2 of 2
    • Use the wrench to remove the bolt that is placed beside the wire connector.
    • Simply pull out the connector.
  4. 2019 Honda Civic Spark Plugs Replacement: step 4, image 1 of 3 2019 Honda Civic Spark Plugs Replacement: step 4, image 2 of 3 2019 Honda Civic Spark Plugs Replacement: step 4, image 3 of 3
    • Make sure the spark plug area is dry before removing the spark plug.
    • Attach the socket to the socket wrench.
    • Put the socket inside the cylinder head and twist the socket wrench to remove the spark plug.
  5. 2019 Honda Civic Spark Plugs Replacement: step 5, image 1 of 1
    • Inspect the new spark plug to ensure that it is completely dry.
  6. 2019 Honda Civic Spark Plugs Replacement: step 6, image 1 of 2 2019 Honda Civic Spark Plugs Replacement: step 6, image 2 of 2
    • Remove the old spark plug and attach the new spark plug to the socket.
    • Place the socket back in the cylinder head and twist the socket wrench to install the spark plug.
  7. 2019 Honda Civic Spark Plugs Replacement: step 7, image 1 of 1
    • Connect the wire back to the spark plug.
  8. 2019 Honda Civic Spark Plugs Replacement: step 8, image 1 of 1
    • Place the engine cover over the engine and reinstall the bolts using the wrench.
Finish Line
4 other people completed this guide.
Bouttia Oshrieh
265 Reputation
1 Guide authored
One Comment
Very informative.
Anwar Kazmi - Reply
Past 24 Hours: 5
Past 7 Days: 28
Past 30 Days: 116
All Time: 9,838
