2019 Toyota Highlander Cabin Air Filter Replacement
  1. 2019 Toyota Highlander Cabin Air Filter Replacement, Cabin Air Filter: step 1, image 1 of 2 2019 Toyota Highlander Cabin Air Filter Replacement, Cabin Air Filter: step 1, image 2 of 2
    • Open the glove compartment and take everything out.
  2. 2019 Toyota Highlander Cabin Air Filter Replacement: step 2, image 1 of 3 2019 Toyota Highlander Cabin Air Filter Replacement: step 2, image 2 of 3 2019 Toyota Highlander Cabin Air Filter Replacement: step 2, image 3 of 3
    • Press the tabs on the sides of the glove compartment until they are released.
    • Please press the sides gently to avoid any damage.
  3. 2019 Toyota Highlander Cabin Air Filter Replacement: step 3, image 1 of 1
    • Once the tabs are released, remove the entire glove compartment.
  4. 2019 Toyota Highlander Cabin Air Filter Replacement: step 4, image 1 of 3 2019 Toyota Highlander Cabin Air Filter Replacement: step 4, image 2 of 3 2019 Toyota Highlander Cabin Air Filter Replacement: step 4, image 3 of 3
    • Open the second cover. Position your finger where the red circle is pointing in the first image, then lower it.
  5. 2019 Toyota Highlander Cabin Air Filter Replacement: step 5, image 1 of 3 2019 Toyota Highlander Cabin Air Filter Replacement: step 5, image 2 of 3 2019 Toyota Highlander Cabin Air Filter Replacement: step 5, image 3 of 3
    • Press the tabs on the side of the third cover. Remove the cover.
    • Do not apply heavy force to prevent damage.
  6. 2019 Toyota Highlander Cabin Air Filter Replacement: step 6, image 1 of 3 2019 Toyota Highlander Cabin Air Filter Replacement: step 6, image 2 of 3 2019 Toyota Highlander Cabin Air Filter Replacement: step 6, image 3 of 3
    • Pull the filter out. If the filter is really dirty, then replace it with a new one. Otherwise, clean the filter and return it to position.
Endraws Estefan
160 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 8
Past 7 Days: 41
Past 30 Days: 241
All Time: 5,393
