2021 Honda HR-V Rear Signal Light Bulb Replacement
  1. 2021 Honda HR-V Rear Signal Light Bulb Replacement, Rear Signal Light Bulb: step 1, image 1 of 1
    • Press the tailgate release button and lift open the rear hatch.
  2. 2021 Honda HR-V Rear Signal Light Bulb Replacement: step 2, image 1 of 3 2021 Honda HR-V Rear Signal Light Bulb Replacement: step 2, image 2 of 3 2021 Honda HR-V Rear Signal Light Bulb Replacement: step 2, image 3 of 3
    • Remove the two screws beside each tail light assembly (four total) using a Phillips #1 screwdriver.
  3. 2021 Honda HR-V Rear Signal Light Bulb Replacement: step 3, image 1 of 2 2021 Honda HR-V Rear Signal Light Bulb Replacement: step 3, image 2 of 2
    • Place both hands on the tail light assembly and pull it directly outwards (away from the vehicle).
    • The tail light assembly will still be connected to the vehicle by wiring, so make sure to be careful when pulling the light assembly out.
  4. 2021 Honda HR-V Rear Signal Light Bulb Replacement: step 4, image 1 of 3 2021 Honda HR-V Rear Signal Light Bulb Replacement: step 4, image 2 of 3 2021 Honda HR-V Rear Signal Light Bulb Replacement: step 4, image 3 of 3
    • Remove the rear signal light bulb from the light assembly by rotating the bulb socket counterclockwise.
  5. 2021 Honda HR-V Rear Signal Light Bulb Replacement: step 5, image 1 of 2 2021 Honda HR-V Rear Signal Light Bulb Replacement: step 5, image 2 of 2
    • Pull apart the light bulb from its socket.
    • Replace with a new light bulb and apply pressure to ensure the light bulb is securely fastened.
  6. 2021 Honda HR-V Rear Signal Light Bulb Replacement: step 6, image 1 of 3 2021 Honda HR-V Rear Signal Light Bulb Replacement: step 6, image 2 of 3 2021 Honda HR-V Rear Signal Light Bulb Replacement: step 6, image 3 of 3
    • Slide the light assembly into the raised white plastic attached to the vehicle.
    • Align the holes on the light assembly to the holes on the vehicle and fasten the bolts into position.
Finish Line
Guadalupe Guevara
133 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 12
Past 30 Days: 52
All Time: 1,214
