360fly 4K SD Card Replacement
  1. 360fly 4K SD Card Replacement, Battery: step 1, image 1 of 1
    • Flip the camera upside down and peel off the two plastic screw covers with the metal spudger to reveal the screws.
  2. 360fly 4K SD Card Replacement: step 2, image 1 of 1
    • Remove the two 5 mm screws from the bottom of the camera with a T4 screwdriver.
  3. 360fly 4K SD Card Replacement: step 3, image 1 of 2 360fly 4K SD Card Replacement: step 3, image 2 of 2
    • Gently pry the plastic ring from around the charging plate with the metal spudger.
    • Remove the outside shell by pressing against the center of the charging plate and pulling the bottom shell away from the top shell.
  4. 360fly 4K SD Card Replacement: step 4, image 1 of 1
    • Remove the five 2 mm screws using a T4 screwdriver.
    • Pull off the charging plate assembly.
  5. 360fly 4K SD Card Replacement: step 5, image 1 of 2 360fly 4K SD Card Replacement: step 5, image 2 of 2
    • Gently pry the plug off the port on the circuit board with a plastic opening tool.
    • Remove the four 2 mm screws using a T4 screwdriver.
    • Remove the circuit board from the device.
  6. 360fly 4K SD Card Replacement: step 6, image 1 of 3 360fly 4K SD Card Replacement: step 6, image 2 of 3 360fly 4K SD Card Replacement: step 6, image 3 of 3
    • Remove the five 4 mm screws around the battery assembly with a T4 screwdriver.
    • Lift the battery assembly and gently pry the plug out of its port on the board below with a plastic opening tool.
    • Press the battery from the back of the battery assembly to remove it with a plastic opening tool until the glue releases the battery.
    • Potential for device damage: Do not puncture or bend the battery. Use a small amount of heat to assist in softening the adhesive if necessary.
  7. 360fly 4K SD Card Replacement, SD Card: step 7, image 1 of 1
    • Gently pry the plug from the motherboard and remove the motherboard from the assembly.
  8. 360fly 4K SD Card Replacement: step 8, image 1 of 1
    • Remove the three 3 mm screws from the circuit assembly with a T4 screwdriver.
  9. 360fly 4K SD Card Replacement: step 9, image 1 of 1
    • Gently pry out the plug from the circuit assembly.
  10. 360fly 4K SD Card Replacement: step 10, image 1 of 1
    • Press and release the SD card to remove it from the circuit assembly.
5 other people completed this guide.
Jacob Herron
463 Reputation
3 Guides authored
IUPUI, Team S5-G3, Baechle Fall 2017 Member of IUPUI, Team S5-G3, Baechle Fall 2017
IUPUI-BAECHLE-F17S5G3
3 Members
3 Guides authored
1 Guide Comment
Really useful guide, thanks
John Erikson - Reply Share
Past 24 Hours: 1
Past 7 Days: 11
Past 30 Days: 48
All Time: 1,413
