422TTL modification for Bench DC Power
  1. 422TTL modification for Bench DC Power, Disassemble Unit: step 1, image 1 of 3 422TTL modification for Bench DC Power, Disassemble Unit: step 1, image 2 of 3 422TTL modification for Bench DC Power, Disassemble Unit: step 1, image 3 of 3
    • Remove side sticker (DC Power 12VDC)
    • Remove hardware (Screws and metal tabs)
    • Carefully lift 4 tabs (2 per side) to split unit into two halves.
  2. 422TTL modification for Bench DC Power, Remove PCB and Remove/desolder  power jack: step 2, image 1 of 3 422TTL modification for Bench DC Power, Remove PCB and Remove/desolder  power jack: step 2, image 2 of 3 422TTL modification for Bench DC Power, Remove PCB and Remove/desolder  power jack: step 2, image 3 of 3
    • Remove the PCB from housing, examining where the headphone style power adapter attaches.
    • Desolder and remove the power adapter.
  3. 422TTL modification for Bench DC Power, Solder new power lines to the PCB.: step 3, image 1 of 3 422TTL modification for Bench DC Power, Solder new power lines to the PCB.: step 3, image 2 of 3 422TTL modification for Bench DC Power, Solder new power lines to the PCB.: step 3, image 3 of 3
    • Positive (red) and negative (black) power lines should attach where the socket was removed.
warrenjrose
97 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 42
