5 Tips & Tricks
Video Overview
  1. 5 Tips & Tricks, SECRET CODES: step 1, image 1 of 3 5 Tips & Tricks, SECRET CODES: step 1, image 2 of 3 5 Tips & Tricks, SECRET CODES: step 1, image 3 of 3
    • Enter the code from the phone dialer app:
    • *#06# -IMEI number
    • *#1234# - firmware version
    • *#0228# - battery info
  2. 5 Tips & Tricks, HIDDEN TEST MENU: step 2, image 1 of 3 5 Tips & Tricks, HIDDEN TEST MENU: step 2, image 2 of 3 5 Tips & Tricks, HIDDEN TEST MENU: step 2, image 3 of 3
    • Use this code *#0*# to enter the phone into the test menu.
    • From this menu you can run tests for vibration, RGB colors, touch-screen, vibration, loudspeaker output, camera, sensor check and so on.
  3. 5 Tips & Tricks, SAFE MODE: step 3, image 1 of 3 5 Tips & Tricks, SAFE MODE: step 3, image 2 of 3 5 Tips & Tricks, SAFE MODE: step 3, image 3 of 3
    • Switch off the phone.
    • Press and holdthe Volume Down and the Power buttons.
    • When you see the Galaxy logo, release only the Power button
    • Now all third-party apps (apps that are installed by you) are disabled.
    • To exit Safe mode just tap on the Safe mode notification or restart the device manually.
  4. 5 Tips & Tricks, DEVELOPER OPTIONS: step 4, image 1 of 3 5 Tips & Tricks, DEVELOPER OPTIONS: step 4, image 2 of 3 5 Tips & Tricks, DEVELOPER OPTIONS: step 4, image 3 of 3
    • Go to >Menu >Settings >About device, Scroll down to Build number, and tap it seven times.
    • Do not change the options if you do not know what you're doing.
  5. 5 Tips & Tricks, SNAPSHOT: step 5, image 1 of 2 5 Tips & Tricks, SNAPSHOT: step 5, image 2 of 2
    • Press the Power and Home buttons at the same time until a shutter sound is heard or you see a visual indicating a picture was taken.
    • That's all. Did you like this guide?
46 other people completed this guide.
ZFix
196,103 Reputation
330 Guides authored
Master Techs Member of Master Techs
Community
331 Members
1,457 Guides authored
1 Guide Comment
How to put mobile internet speed can you have sample code?
Richad Paker - Reply
Past 24 Hours: 3
Past 7 Days: 6
Past 30 Days: 32
All Time: 20,434
