8BitDo NES30 Pro Gamepad Button Replacement
  1. 8BitDo NES30 Pro Gamepad Button Replacement, Button: step 1, image 1 of 2 8BitDo NES30 Pro Gamepad Button Replacement, Button: step 1, image 2 of 2
    • Hold the controller with its back facing towards you.
    • Insert an opening pick between the L1 or R1 button and the backplate, and pry the backplate off of the controller.
  2. 8BitDo NES30 Pro Gamepad Button Replacement: step 2, image 1 of 2 8BitDo NES30 Pro Gamepad Button Replacement: step 2, image 2 of 2
    • Place the controller face down on a solid surface.
    • Remove the seven screws with the Phillips #00 screwdriver.
  3. 8BitDo NES30 Pro Gamepad Button Replacement: step 3, image 1 of 1
    • Lift the body of the controller up and away from the controller's face and buttons.
  4. 8BitDo NES30 Pro Gamepad Button Replacement: step 4, image 1 of 2 8BitDo NES30 Pro Gamepad Button Replacement: step 4, image 2 of 2
    • Lift away the black rubber pads that sit between the face buttons and body of the controller.
  5. 8BitDo NES30 Pro Gamepad Button Replacement: step 5, image 1 of 1
    • Lift the buttons out of the face of the controller.
  6. 8BitDo NES30 Pro Gamepad Button Replacement: step 6, image 1 of 2 8BitDo NES30 Pro Gamepad Button Replacement: step 6, image 2 of 2
    • Align the notches of the face buttons to put them back into place.
    • Each button has a unique notch pattern so it can't be replaced incorrectly.
    • Attach the rubber pads by placing their smaller and larger holes around the matching size pegs.
2 other people completed this guide.
4 Guide Comments
Hello there, any idea where I can find those black rubber pads for replacement ? mine is torn.
Thx
Ben Kakita - Reply
sorry, i try to search every where, have a tone for other controller, even have for 8bitdo snes, but not for nes 30 pro.
if you find it, answer on that chat. Good luck
Freeman loran - Reply
I wrote 8BitDo support, and explained the issue. They sent me some pads for the price of postage, but only for the buttons -- they didn't send any for the d-pad, which I feel is probably an error on their part.
Izaak Xavier - Reply
The screws in the N30 Pro are #6 Torx now
Matt Baker - Reply
Past 24 Hours: 6
Past 7 Days: 29
Past 30 Days: 90
All Time: 2,746
