8BitDo SN30 Pro+ Controller Analog Sticks Replacement
  1. 8BitDo SN30 Pro+ Controller Analog Sticks Replacement, Remove Battery: step 1, image 1 of 3 8BitDo SN30 Pro+ Controller Analog Sticks Replacement, Remove Battery: step 1, image 2 of 3 8BitDo SN30 Pro+ Controller Analog Sticks Replacement, Remove Battery: step 1, image 3 of 3
    • Place the controller face down.
    • Remove the battery cover.
    • Remove rechargeable battery or AA batteries.
  2. 8BitDo SN30 Pro+ Controller Analog Sticks Replacement, Remove Trigger Buttons: step 2, image 1 of 2 8BitDo SN30 Pro+ Controller Analog Sticks Replacement, Remove Trigger Buttons: step 2, image 2 of 2
    • Remove L2 and R2 trigger buttons by pushing them away from the grips.
  3. 8BitDo SN30 Pro+ Controller Analog Sticks Replacement, Remove Screws: step 3, image 1 of 2 8BitDo SN30 Pro+ Controller Analog Sticks Replacement, Remove Screws: step 3, image 2 of 2
    Tool used on this step:
    Buy
    • Use Tweezers to uncover two screws under the label in the battery compartment.
    • Use a T6 screwdriver to remove the four 7.3 mm screws securing the rear cover.
  4. 8BitDo SN30 Pro+ Controller Analog Sticks Replacement, Unclip Covers: step 4, image 1 of 3 8BitDo SN30 Pro+ Controller Analog Sticks Replacement, Unclip Covers: step 4, image 2 of 3 8BitDo SN30 Pro+ Controller Analog Sticks Replacement, Unclip Covers: step 4, image 3 of 3
    • At the end of each grip, pry apart the covers.
    • Use fingernail or opening pick to undo the two top clips.
    • One clip next to L button.
    • One clip next to R button
    • Undo the final clip between the joysticks.
  5. 8BitDo SN30 Pro+ Controller Analog Sticks Replacement, Separate Covers: step 5, image 1 of 1
    • Carefully move the rear cover away and from the front cover. Place it to the left.
    • Do not completely separate. The two halves are still attached via a white ribbon cable.
  6. 8BitDo SN30 Pro+ Controller Analog Sticks Replacement, Remove Ribbon Cable: step 6, image 1 of 3 8BitDo SN30 Pro+ Controller Analog Sticks Replacement, Remove Ribbon Cable: step 6, image 2 of 3 8BitDo SN30 Pro+ Controller Analog Sticks Replacement, Remove Ribbon Cable: step 6, image 3 of 3
    • Unlock the ribbon cable by push open the black plastic tab.
    • The tab will slide about 1.5mm
    • Pull the ribbon cable out of the connector in the direction of the cable.
  7. 8BitDo SN30 Pro+ Controller Analog Sticks Replacement, Remove Caps: step 7, image 1 of 2 8BitDo SN30 Pro+ Controller Analog Sticks Replacement, Remove Caps: step 7, image 2 of 2
    • Grab the top and pull straight up on the joystick cap. Pulling out the caps one-by-one.
  8. 8BitDo SN30 Pro+ Controller Analog Sticks Replacement, Remove Screws: step 8, image 1 of 3 8BitDo SN30 Pro+ Controller Analog Sticks Replacement, Remove Screws: step 8, image 2 of 3 8BitDo SN30 Pro+ Controller Analog Sticks Replacement, Remove Screws: step 8, image 3 of 3
    • Use a Phillips screwdriver to remove the nine 5.2 mm screws securing the rear circuit board.
    • Four around the Right stick
    • Four around the Left stick
    • One next to the Battery connector
  9. 8BitDo SN30 Pro+ Controller Analog Sticks Replacement, Separate Rear Board: step 9, image 1 of 3 8BitDo SN30 Pro+ Controller Analog Sticks Replacement, Separate Rear Board: step 9, image 2 of 3 8BitDo SN30 Pro+ Controller Analog Sticks Replacement, Separate Rear Board: step 9, image 3 of 3
    • Pull the two rumble motors out of their housings.
    • Grab the analog sticks to pull out the circuit board
  10. 8BitDo SN30 Pro+ Controller Analog Sticks Replacement, Desolder Analog Sticks: step 10, image 1 of 3 8BitDo SN30 Pro+ Controller Analog Sticks Replacement, Desolder Analog Sticks: step 10, image 2 of 3 8BitDo SN30 Pro+ Controller Analog Sticks Replacement, Desolder Analog Sticks: step 10, image 3 of 3
    • Flip over the rear board.
    • Using a soldering iron to desolder all the joints of the analog sticks.
    • Make sure all the solder holes are open on the circuit board.
    • Refer to the following solder guide if necessary: How To Solder and Desolder Connections
3 other people completed this guide.
Brian W
1,773 Reputation
8 Guides authored
5 Guide Comments
Thanks for the guide! What form factor does the sn30 use for its sticks?
Joshua Randall - Reply
Ever figure it out? I'm wondering the same.
Peter Hindes -
I asked 8BitDo directly and they sent me this link https://tech.alpsalpine.com/e/products/d...
Stepan Orda -
im just trying to replace the worn out joystick wtf
JonnyRoboto - Reply
Great guide, thanks! I only needed to get as far as replacing the caps but was useful to know where the hidden screws and clips were ahead of time.
Liam Jackson - Reply
Past 24 Hours: 3
Past 7 Days: 45
Past 30 Days: 196
All Time: 12,931
