8BitDo SN30 Pro+ Controller Triggers Replacement
  1. 8BitDo SN30 Pro+ Controller Triggers Replacement, Remove Battery: step 1, image 1 of 3 8BitDo SN30 Pro+ Controller Triggers Replacement, Remove Battery: step 1, image 2 of 3 8BitDo SN30 Pro+ Controller Triggers Replacement, Remove Battery: step 1, image 3 of 3
    • Place the controller face down.
    • Remove the battery cover.
    • Remove rechargeable battery or AA batteries.
  2. 8BitDo SN30 Pro+ Controller Triggers Replacement, Remove Trigger Buttons: step 2, image 1 of 2 8BitDo SN30 Pro+ Controller Triggers Replacement, Remove Trigger Buttons: step 2, image 2 of 2
    • Remove L2 and R2 trigger buttons by pushing them away from the grips.
  3. 8BitDo SN30 Pro+ Controller Triggers Replacement, Remove Screws: step 3, image 1 of 2 8BitDo SN30 Pro+ Controller Triggers Replacement, Remove Screws: step 3, image 2 of 2
    Tool used on this step:
    Buy
    • Use Tweezers to uncover two screws under the label in the battery compartment.
    • Use a T6 screwdriver to remove the four 7.3 mm screws securing the rear cover.
  4. 8BitDo SN30 Pro+ Controller Triggers Replacement, Unclip Covers: step 4, image 1 of 3 8BitDo SN30 Pro+ Controller Triggers Replacement, Unclip Covers: step 4, image 2 of 3 8BitDo SN30 Pro+ Controller Triggers Replacement, Unclip Covers: step 4, image 3 of 3
    • At the end of each grip, pry apart the covers.
    • Use fingernail or opening pick to undo the two top clips.
    • One clip next to L button.
    • One clip next to R button
    • Undo the final clip between the joysticks.
  5. 8BitDo SN30 Pro+ Controller Triggers Replacement, Separate Covers: step 5, image 1 of 1
    • Carefully move the rear cover away and from the front cover. Place it to the left.
    • Do not completely separate. The two halves are still attached via a white ribbon cable.
  6. 8BitDo SN30 Pro+ Controller Triggers Replacement, Remove Ribbon Cable: step 6, image 1 of 3 8BitDo SN30 Pro+ Controller Triggers Replacement, Remove Ribbon Cable: step 6, image 2 of 3 8BitDo SN30 Pro+ Controller Triggers Replacement, Remove Ribbon Cable: step 6, image 3 of 3
    • Unlock the ribbon cable by push open the black plastic tab.
    • The tab will slide about 1.5mm
    • Pull the ribbon cable out of the connector in the direction of the cable.
  7. 8BitDo SN30 Pro+ Controller Triggers Replacement, Remove Screws: step 7, image 1 of 3 8BitDo SN30 Pro+ Controller Triggers Replacement, Remove Screws: step 7, image 2 of 3 8BitDo SN30 Pro+ Controller Triggers Replacement, Remove Screws: step 7, image 3 of 3
    • Use a Phillips screwdriver to remove the seven screws securing the main circuit board.
    • Six 10.1mm screws
    • One 5.8mm screws
  8. 8BitDo SN30 Pro+ Controller Triggers Replacement, Separate Main Board: step 8, image 1 of 3 8BitDo SN30 Pro+ Controller Triggers Replacement, Separate Main Board: step 8, image 2 of 3 8BitDo SN30 Pro+ Controller Triggers Replacement, Separate Main Board: step 8, image 3 of 3
    • Slide the R buttons up and off its peg.
    • Slide the L button up and off its peg.
    • Remove the main board by rotating it towards the USB-C port. Then lift it out.
  9. 8BitDo SN30 Pro+ Controller Triggers Replacement, Remove Trigger Assembly: step 9, image 1 of 3 8BitDo SN30 Pro+ Controller Triggers Replacement, Remove Trigger Assembly: step 9, image 2 of 3 8BitDo SN30 Pro+ Controller Triggers Replacement, Remove Trigger Assembly: step 9, image 3 of 3
    • Release the three clips holding the trigger assembly to the main board.
    • Repeat with the other side.
  10. 8BitDo SN30 Pro+ Controller Triggers Replacement, Remove Trigger: step 10, image 1 of 3 8BitDo SN30 Pro+ Controller Triggers Replacement, Remove Trigger: step 10, image 2 of 3 8BitDo SN30 Pro+ Controller Triggers Replacement, Remove Trigger: step 10, image 3 of 3
    • Bend the plastic tab over the locking hook. It helps to push the trigger back slightly, with your other hand.
    • Gently pry the each side of the trigger out of the round clips.
    • Both conductive pads are now accessible.
Brian W
1,773 Reputation
8 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 24
Past 30 Days: 87
All Time: 4,281
