ACER Aspire 7750G-6645 Fan Replacement
  1. ACER Aspire 7750G-6645 Fan Replacement, Keyboard: step 1, image 1 of 2 ACER Aspire 7750G-6645 Fan Replacement, Keyboard: step 1, image 2 of 2
    • Turn off the laptop, and open the lid.
    • Separate the first two layers by prying them apart, using a spudger.
  2. ACER Aspire 7750G-6645 Fan Replacement: step 2, image 1 of 3 ACER Aspire 7750G-6645 Fan Replacement: step 2, image 2 of 3 ACER Aspire 7750G-6645 Fan Replacement: step 2, image 3 of 3
    • Lift the keyboard, so that its ribbon is visible.
    • Remove the ribbon from the board by using a small metal spudger or flathead screwdriver. (if needed)
  3. ACER Aspire 7750G-6645 Fan Replacement, Fan: step 3, image 1 of 2 ACER Aspire 7750G-6645 Fan Replacement, Fan: step 3, image 2 of 2
    • Remove the two 3mm screws using the Phillips #00 screwdriver.
    • Remove the two 6mm screws using the same screwdriver.
    • Remove the fan cover to gain access to the fan.
  4. ACER Aspire 7750G-6645 Fan Replacement: step 4, image 1 of 2 ACER Aspire 7750G-6645 Fan Replacement: step 4, image 2 of 2
    Tool used on this step:
    Desoldering Pump
    $3.99
    Buy
    • Lift the fan up and away from the device. Do not remove the fan from the device.
    • Desolder the attached part using a Soldering Iron to heat it up and remove the leftover heated lead by using a Desoldering Pump.
    • If you aren't familiar with soldering, read our How to Solder and Desolder Connections guide for more information.
taylan ergil
85 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 8
All Time: 652
