ACER Aspire 7750G-6645 Hard Drive Replacement
  1. ACER Aspire 7750G-6645 Hard Drive Replacement, Back Cover: step 1, image 1 of 1
    • Remove three 60mm Phillips #00 screws that are holding the bottom cover in place.
  2. ACER Aspire 7750G-6645 Hard Drive Replacement: step 2, image 1 of 1
    • Lift up the back cover of the device, you may need to use a spudger to assist.
  3. ACER Aspire 7750G-6645 Hard Drive Replacement, Hard Drive: step 3, image 1 of 3 ACER Aspire 7750G-6645 Hard Drive Replacement, Hard Drive: step 3, image 2 of 3 ACER Aspire 7750G-6645 Hard Drive Replacement, Hard Drive: step 3, image 3 of 3
    • Remove two 4mm Phillips #00 screws that are holding the hard drive in place.
  4. ACER Aspire 7750G-6645 Hard Drive Replacement: step 4, image 1 of 2 ACER Aspire 7750G-6645 Hard Drive Replacement: step 4, image 2 of 2
    • Push the hard drive to the right and push it upward to remove. You may need a spudger or plastic opening tool to assist you with this step.
Thong
199 Reputation
2 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 25
All Time: 2,297
