AEE Mach 1 Motherboard Replacement
  1. AEE Mach 1 Motherboard Replacement, Motherboard: step 1, image 1 of 1
    • Take out the AEE Mach 1 and place it on a flat surface with its propellers facing up.
  2. AEE Mach 1 Motherboard Replacement: step 2, image 1 of 2 AEE Mach 1 Motherboard Replacement: step 2, image 2 of 2
    • Holding the base of each propeller still, unscrew the propeller clockwise for each arm.
  3. AEE Mach 1 Motherboard Replacement: step 3, image 1 of 1
    • Flip the drone so that the bottom of the AEE Mach 1 is facing up.
  4. AEE Mach 1 Motherboard Replacement: step 4, image 1 of 1
    • Remove the five screws on the drone's arms using a Torx T5 screwdriver.
  5. AEE Mach 1 Motherboard Replacement: step 5, image 1 of 1
    • Gently pry open the top panel of the drone using a spudger.
    • Do not completely remove the panel, as there will still be wired connections between the two halves.
  6. AEE Mach 1 Motherboard Replacement: step 6, image 1 of 1
    • Take out and set aside the battery pack, located on the back of the AEE Mach 1.
  7. AEE Mach 1 Motherboard Replacement: step 7, image 1 of 1
    • Rotate the top panel slightly to reveal the four screws beneath each propellor arm.
    • Remove each of the four screws with a Phillips #0 screwdriver.
    • Lift off the top panel, as it should now be free from the rest of the device.
  8. AEE Mach 1 Motherboard Replacement: step 8, image 1 of 2 AEE Mach 1 Motherboard Replacement: step 8, image 2 of 2
    • Remove the four screws from each corner of the motherboard with a Phillips #00 screwdriver.
  9. AEE Mach 1 Motherboard Replacement: step 9, image 1 of 2 AEE Mach 1 Motherboard Replacement: step 9, image 2 of 2
    • Use a plastic spudger to gently remove the copper tape from the mother board.
  10. AEE Mach 1 Motherboard Replacement: step 10, image 1 of 1
    • Peeling up the copper tape will expose another metal chip that has wires that are soldered to the mother board.
    • Remove the four screws holding the secondary board in place using a Phillips #00 screwdriver.
  11. AEE Mach 1 Motherboard Replacement: step 11, image 1 of 3 AEE Mach 1 Motherboard Replacement: step 11, image 2 of 3 AEE Mach 1 Motherboard Replacement: step 11, image 3 of 3
    Tool used on this step:
    Buy
    • Remove the ZIF connector joining the motherboard and secondary board by prying up the locking black tab and pulling out the cable with some blunt nosed tweezers.
    • Desolder the red and black wires joining the two boards.
    • For help soldering, check out our How To Solder and Desolder Connections guide.
  12. AEE Mach 1 Motherboard Replacement: step 12, image 1 of 1
    • Remove the motherboard by lifting it from the case.
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 3
All Time: 323
