AKASO KingPad A90 Battery Replacement
  1. AKASO KingPad A90 Battery Replacement, Battery: step 1, image 1 of 3 AKASO KingPad A90 Battery Replacement, Battery: step 1, image 2 of 3 AKASO KingPad A90 Battery Replacement, Battery: step 1, image 3 of 3
    • Remove screws.
    • Insert spudger tool on the middle of the left side, between the white and black plastic.
    • Slide in a plastic opening tool and use it to further pull the back off.
    • Work your way around the edge of the tablet with the plastic opening tool and insert more as needed.
    • Pull off the back cover.
  2. AKASO KingPad A90 Battery Replacement: step 2, image 1 of 3 AKASO KingPad A90 Battery Replacement: step 2, image 2 of 3 AKASO KingPad A90 Battery Replacement: step 2, image 3 of 3
    • Using the black plastic spudger tool, insert it under a corner of the battery.
    • Work your way around the edges to pry the battery and loosen it from the adhesive.
    • Remove the battery.
  3. AKASO KingPad A90 Battery Replacement: step 3, image 1 of 3 AKASO KingPad A90 Battery Replacement: step 3, image 2 of 3 AKASO KingPad A90 Battery Replacement: step 3, image 3 of 3
    • Locate the battery unit solder points and note where it is attached to the motherboard.
    • Plug in your soldering iron/pen and wait the required amount of time to heat up.
    • Be careful with the iron as the tip is very hot and it could burn you or the tablet
    • Apply a small amount of pressure with the iron on the solder points until the joints come loose and the wires move freely away from the board
    • Remove the battery unit
  4. AKASO KingPad A90 Battery Replacement: step 4, image 1 of 3 AKASO KingPad A90 Battery Replacement: step 4, image 2 of 3 AKASO KingPad A90 Battery Replacement: step 4, image 3 of 3
    • Locate the red and black wire ends of your new battery
    • Take your solder out and place it on the point with the wire
    • Use the iron/pen to slowly melt a small piece of solder onto the point and let it solidify.
    • Be careful not to use too much solder as a large blob could result in a short on your device
    • Repeat this step for the other point
  5. AKASO KingPad A90 Battery Replacement: step 5, image 1 of 3 AKASO KingPad A90 Battery Replacement: step 5, image 2 of 3 AKASO KingPad A90 Battery Replacement: step 5, image 3 of 3
    • Replace the back cover with the new part in place.
    • Gently press the speaker into place.
    • Don't let the volume rocker unit fall out of place.
    • Replace the screws.
Finish Line
5 other people completed this guide.
Daniel Garcia
179 Reputation
2 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 15
All Time: 1,986
