AKASO KingPad A90 Camera (Rear and Front) Unit Replacement
  1. AKASO KingPad A90 Camera (Rear and Front) Unit Replacement, Camera (Rear and Front) Unit: step 1, image 1 of 3 AKASO KingPad A90 Camera (Rear and Front) Unit Replacement, Camera (Rear and Front) Unit: step 1, image 2 of 3 AKASO KingPad A90 Camera (Rear and Front) Unit Replacement, Camera (Rear and Front) Unit: step 1, image 3 of 3
    • Remove screws.
    • Insert spudger tool on the middle of the left side, between the white and black plastic.
    • Slide in a plastic opening tool and use it to further pull the back off.
    • Work your way around the edge of the tablet with the plastic opening tool and insert more as needed.
    • Pull off the back cover.
  2. AKASO KingPad A90 Camera (Rear and Front) Unit Replacement: step 2, image 1 of 3 AKASO KingPad A90 Camera (Rear and Front) Unit Replacement: step 2, image 2 of 3 AKASO KingPad A90 Camera (Rear and Front) Unit Replacement: step 2, image 3 of 3
    Tool used on this step:
    Buy
    • Locate the camera unit and note where it is attached to the motherboard.
    • Grasp the camera unit with tweezers or fingers, and pull firmly to remove it from the adhesive holding it to the motherboard.
    • Be careful when lifting up the camera unit. Don’t tear the ribbon cable! Ensure that you examine the second picture of this step.
    • Using the spudger, carefully loosen the slot's plastic cover piece holding the ribbon cable in place.
    • Pull the ribbon cable out.
    • Remove the old adhesive with tweezers.
  3. AKASO KingPad A90 Camera (Rear and Front) Unit Replacement: step 3, image 1 of 3 AKASO KingPad A90 Camera (Rear and Front) Unit Replacement: step 3, image 2 of 3 AKASO KingPad A90 Camera (Rear and Front) Unit Replacement: step 3, image 3 of 3
    • Apply a small square of new adhesive in the same spot as the old adhesive was previously.
    • Gently slide the new camera unit's ribbon cable into the slot.
    • Give the ribbon a firm push to make sure it has made contact.
    • Press the plastic cover piece back in place with the spudger.
    • Firmly press the new camera onto the adhesive, making sure to line it up correctly.
  4. AKASO KingPad A90 Camera (Rear and Front) Unit Replacement: step 4, image 1 of 3 AKASO KingPad A90 Camera (Rear and Front) Unit Replacement: step 4, image 2 of 3 AKASO KingPad A90 Camera (Rear and Front) Unit Replacement: step 4, image 3 of 3
    • Replace the back cover with the new camera unit in place.
    • Gently press the speaker into place.
    • Don't let the volume rocker unit fall out of place.
    • Replace the screws.
Finish Line
2 other people completed this guide.
Miles
260 Reputation
2 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 11
All Time: 701
