AKASO KingPad A90 Rear Speaker Replacement
  1. AKASO KingPad A90 Rear Speaker Replacement, Rear Speaker: step 1, image 1 of 3 AKASO KingPad A90 Rear Speaker Replacement, Rear Speaker: step 1, image 2 of 3 AKASO KingPad A90 Rear Speaker Replacement, Rear Speaker: step 1, image 3 of 3
    • Remove screws.
    • Insert spudger tool on the middle of the left side, between the white and black plastic.
    • Slide in a plastic opening tool and use it to further pull the back off.
    • Work your way around the edge of the tablet with the plastic opening tool and insert more as needed.
    • Pull off the back cover.
  2. AKASO KingPad A90 Rear Speaker Replacement: step 2, image 1 of 3 AKASO KingPad A90 Rear Speaker Replacement: step 2, image 2 of 3 AKASO KingPad A90 Rear Speaker Replacement: step 2, image 3 of 3
    • Plug in soldering iron and let it warm up for ten minutes.
    • Locate the speaker solder points and note where it is attached to the motherboard.
    • Solder the old speaker out of its mark. (Touch the tip of the solder iron to the soldering point).
  3. AKASO KingPad A90 Rear Speaker Replacement: step 3, image 1 of 3 AKASO KingPad A90 Rear Speaker Replacement: step 3, image 2 of 3 AKASO KingPad A90 Rear Speaker Replacement: step 3, image 3 of 3
    • Solder the new speaker onto the points where the old speaker was.
  4. AKASO KingPad A90 Rear Speaker Replacement: step 4, image 1 of 3 AKASO KingPad A90 Rear Speaker Replacement: step 4, image 2 of 3 AKASO KingPad A90 Rear Speaker Replacement: step 4, image 3 of 3
    • Replace the back cover with the new rear speaker unit in place.
    • Gently press the speaker into place.
    • Don't let the volume rocker unit fall out of place.
    • Replace the screws.
Finish Line
camchristo
71 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 8
All Time: 380
