AKASO KingPad A90 Volume Rocker/Power Button Unit Replacement
  1. AKASO KingPad A90 Volume Rocker/Power Button Unit Replacement, Volume Rocker/Power Button Unit: step 1, image 1 of 3 AKASO KingPad A90 Volume Rocker/Power Button Unit Replacement, Volume Rocker/Power Button Unit: step 1, image 2 of 3 AKASO KingPad A90 Volume Rocker/Power Button Unit Replacement, Volume Rocker/Power Button Unit: step 1, image 3 of 3
    • Remove screws
    • Insert spudger tool on the middle of the left side, between the white and black plastic
    • Slide in a plastic opening tool and use it to further pull the back off.
    • Work your way around the edge of the tablet with the plastic opening tool and insert more as needed
    • Pull off the back cover
  2. AKASO KingPad A90 Volume Rocker/Power Button Unit Replacement: step 2, image 1 of 3 AKASO KingPad A90 Volume Rocker/Power Button Unit Replacement: step 2, image 2 of 3 AKASO KingPad A90 Volume Rocker/Power Button Unit Replacement: step 2, image 3 of 3
    • Remove the broken volume rocker/power button unit.
    • Place the new part into the empty slot.
  3. AKASO KingPad A90 Volume Rocker/Power Button Unit Replacement: step 3, image 1 of 3 AKASO KingPad A90 Volume Rocker/Power Button Unit Replacement: step 3, image 2 of 3 AKASO KingPad A90 Volume Rocker/Power Button Unit Replacement: step 3, image 3 of 3
    • Gently press the speaker into place.
    • Replace the back cover with the new part in place.
    • Be careful to not let the volume rocker unit fall out of place.
    • Replace the screws.
Finish Line
2 other people completed this guide.
Miles
260 Reputation
2 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 4
All Time: 519
