ANKER SoundCore Battery/Battery Wire Replacement
  1. ANKER SoundCore Battery/Battery Wire Replacement, Battery/Battery Wire: step 1, image 1 of 3 ANKER SoundCore Battery/Battery Wire Replacement, Battery/Battery Wire: step 1, image 2 of 3 ANKER SoundCore Battery/Battery Wire Replacement, Battery/Battery Wire: step 1, image 3 of 3
    • Use the plastic opening tool to pry off the screen.
    • Remove the screen from the device.
  2. ANKER SoundCore Battery/Battery Wire Replacement: step 2, image 1 of 1
    • Remove the eight 10 mm Phillips #0 screws from the speaker mount.
    • Remove the speaker mount gently.
  3. ANKER SoundCore Battery/Battery Wire Replacement: step 3, image 1 of 3 ANKER SoundCore Battery/Battery Wire Replacement: step 3, image 2 of 3 ANKER SoundCore Battery/Battery Wire Replacement: step 3, image 3 of 3
    • Remove the two 8mm Phillips #0 screws from the circuit board.
    • Remove the circuit board from its mount.
  4. ANKER SoundCore Battery/Battery Wire Replacement: step 4, image 1 of 3 ANKER SoundCore Battery/Battery Wire Replacement: step 4, image 2 of 3 ANKER SoundCore Battery/Battery Wire Replacement: step 4, image 3 of 3
    • Find the battery below the circuit board.
    • It is covered by fuzz that is the same color as the black casing, so it may be hard to see.
    • Pry the battery off using the iFixit opening tool.
    • Remove the battery from its holder.
  5. ANKER SoundCore Battery/Battery Wire Replacement: step 5, image 1 of 1
    • Desolder the battery wires.
    • Remove the battery and battery wire from the device.
    • For more information on soldering and desoldering connections, follow this guide.
7 other people completed this guide.
Lucas Sandsor
313 Reputation
1 Guide authored
Cal Poly, Team S22-G1, Regan Winter 2020 Member of Cal Poly, Team S22-G1, Regan Winter 2020
CPSU-REGAN-W20S22G1
5 Members
7 Guides authored
6 Guide Comments
If a bt speaker battery died,the unit can't power up by cable?
limz555 - Reply Share
Nice guide… showed how to get the grill off… Unfortunately, my circuit board is epoxied in place.
Battery tests ok, but unit won’t turn on. Its going into the bag with other non-working electronics unless you have any ideas. The little speakers look very nice…
manfred.humphries - Reply Share
My Anker works as long as it is plugged in (usb). As soon as the lead is removed, it dies.
David Goodacre - Reply Share
Where do I get the new battery in India?
Raghubir Roy L - Reply Share
What are the specs on the battery, so I can double-check compatibility for a replacement?
Andy Mattson - Reply Share
Past 24 Hours: 7
Past 7 Days: 87
Past 30 Days: 418
All Time: 30,284
