ANKER SoundCore Charging Port Replacement
  1. ANKER SoundCore Charging Port Replacement, Charging Port: step 1, image 1 of 3 ANKER SoundCore Charging Port Replacement, Charging Port: step 1, image 2 of 3 ANKER SoundCore Charging Port Replacement, Charging Port: step 1, image 3 of 3
    • Use the plastic opening tool to pry off the screen.
    • Remove the screen from the device.
  2. ANKER SoundCore Charging Port Replacement: step 2, image 1 of 1
    • Remove the eight 10 mm Phillips #0 screws from the speaker mount.
  3. ANKER SoundCore Charging Port Replacement: step 3, image 1 of 2 ANKER SoundCore Charging Port Replacement: step 3, image 2 of 2
    • Use the metal spludger to pry off speaker mount.
  4. ANKER SoundCore Charging Port Replacement: step 4, image 1 of 1
    • Remove the two 8mm Phillips #0 screws from the circuit board.
  5. ANKER SoundCore Charging Port Replacement: step 5, image 1 of 2 ANKER SoundCore Charging Port Replacement: step 5, image 2 of 2
    • Carefully remove the circuit board from the speaker body.
  6. ANKER SoundCore Charging Port Replacement: step 6, image 1 of 2 ANKER SoundCore Charging Port Replacement: step 6, image 2 of 2
    • Use the iFixit Opening Pick to pry off the charging port cover.
    • Remove the charging port cover.
  7. ANKER SoundCore Charging Port Replacement: step 7, image 1 of 2 ANKER SoundCore Charging Port Replacement: step 7, image 2 of 2
    • Desolder the charging port from the circuit board.
    • Solder a new charging port in place of the old one.
    • For help soldering and desoldering, follow this guide.
3 other people completed this guide.
Briana Kuo
311 Reputation
1 Guide authored
Cal Poly, Team S22-G1, Regan Winter 2020 Member of Cal Poly, Team S22-G1, Regan Winter 2020
CPSU-REGAN-W20S22G1
5 Members
7 Guides authored
4 Guide Comments
Where can I find a replacement port that is compatible?
tommy2197 - Reply
Mike - Reply
The Charging port is an USB Mirco Port. To find right part search for JBL FLIP 3 on ebay or other platforms. It is the same part as used for the Anker SoundCore.
Agi -
Hi I have a Anker soundcore motion plus, the charging port is loose and not charging, it's a usb c, where can I buy that replacement part
.thanks
Justin - Reply
Past 24 Hours: 3
Past 7 Days: 22
Past 30 Days: 105
All Time: 12,906
