ANKER SoundCore Microphone Replacement
  1. ANKER SoundCore Microphone Replacement, Microphone: step 1, image 1 of 3 ANKER SoundCore Microphone Replacement, Microphone: step 1, image 2 of 3 ANKER SoundCore Microphone Replacement, Microphone: step 1, image 3 of 3
    • Use the plastic opening tool to pry off the screen.
    • Remove the screen from the device.
  2. ANKER SoundCore Microphone Replacement: step 2, image 1 of 1
    • Use a Phillips #0 screwdriver to remove the eight 10mm screws securing the speaker mount to the speaker body.
  3. ANKER SoundCore Microphone Replacement: step 3, image 1 of 2 ANKER SoundCore Microphone Replacement: step 3, image 2 of 2
    • Use the metal spudger tool to lift and remove the speaker mount.
    • Ensure all wires remain properly secured to device.
  4. ANKER SoundCore Microphone Replacement: step 4, image 1 of 1
    • Use a Phillips #0 screwdriver to remove two 8mm screws from circuit board.
  5. ANKER SoundCore Microphone Replacement: step 5, image 1 of 1
    • Carefully remove the circuit board from the speaker body.
  6. ANKER SoundCore Microphone Replacement: step 6, image 1 of 2 ANKER SoundCore Microphone Replacement: step 6, image 2 of 2
    • Desolder the two points connecting the microphone to the circuit board.
    • Remove the microphone from circuit board.
    • For help soldering and desoldering follow this guide.
Fiona Schmidt
133 Reputation
1 Guide authored
Cal Poly, Team S22-G1, Regan Winter 2020 Member of Cal Poly, Team S22-G1, Regan Winter 2020
CPSU-REGAN-W20S22G1
5 Members
7 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 24
All Time: 2,985
