APC Smart-UPS SC 450VA Battery Replacement
Sebastian
Sebastian and 2 other contributors
Last updated on April 1, 2024
2 minutes
Easy
Community-Contributed Guide
Introduction
Go to step 1
The APC Smart-UPS is a reliable uninterruptible power supply that provides backup power and surge protection for electronic devices. However, like any battery-powered device, the battery inside the UPS will eventually wear out and need to be replaced. In this guide, we will walk you through the steps to replace the battery in your APC Smart-UPS SC 450VA, including how to remove the old battery and how to install the new battery. By following these steps, you can ensure that your UPS continues to provide reliable backup power for your devices.
iFixit earns commission when you buy through these links.
  1. APC Smart-UPS SC 450VA Battery Replacement, Remove the faceplate: step 1, image 1 of 1
    • Pull on the left corner of the faceplate to remove it.
  2. APC Smart-UPS SC 450VA Battery Replacement, Unscrew the battery cover: step 2, image 1 of 1
    Tool used on this step:
    iFixit Precision 4 mm Screwdriver Bit
    $2.99
    • Use a PH2 screwdriver to unscrew the 4 screws securing the battery cover.
  3. APC Smart-UPS SC 450VA Battery Replacement, Remove the battery: step 3, image 1 of 2 APC Smart-UPS SC 450VA Battery Replacement, Remove the battery: step 3, image 2 of 2
    • Use the pull tab to pull out the battery.
    • Be sure to not pinch the cables between the case and the battery.
    • Unplug the battery connector.
    • Remove the battery.
    • Caution: Don't jab the battery with any sharp tools. A punctured battery may leak dangerous chemicals.
Sebastian
28,112 Reputation
71 Guides authored
German Translators Member of German Translators
Community
35 Members
1,212 Guides authored
4 Comments
this is incorrect, since 1995 all Smart UPS have hot swappable batteries. no need to turn it off, that's the whole point of it being in the front of the device - https://www.apc.com/us/en/faqs/FA303216/
Ryan Matthews - Reply
Thank you, the guide has been adjusted.
Sebastian -
After hot swapping the battery replacement my replace battery LED is still lit. How do I reset that?
Michael Dickson - Reply
You can press and hold the power button for a few seconds to manually run a self-test or just wait until it reaches the next scheduled self-test (every 7 or 14 days depending on configuration). It is recommended to wait at least 24 hours before performing the self test as the new battery needs time to reach capacity.
Sebastian -
Past 24 Hours: 10
Past 7 Days: 56
Past 30 Days: 236
All Time: 6,191
