APC Smart-UPS SMT1500RM2UC Battery Cartridge Replacement
  1. APC Smart-UPS SMT1500RM2UC Battery Cartridge Replacement, Safety Precautions: step 1, image 1 of 1
    • Before you begin your repair, unplug your UPS.
  2. APC Smart-UPS SMT1500RM2UC Battery Cartridge Replacement, Unclip an edge of the front bezel: step 2, image 1 of 3 APC Smart-UPS SMT1500RM2UC Battery Cartridge Replacement, Unclip an edge of the front bezel: step 2, image 2 of 3 APC Smart-UPS SMT1500RM2UC Battery Cartridge Replacement, Unclip an edge of the front bezel: step 2, image 3 of 3
    • Two plastic clips secure the outer edges of the front bezel.
    • Press in one of the clips until it releases.
    • Pull the edge of the front bezel away from the device until the clip comes out of its slot.
  3. APC Smart-UPS SMT1500RM2UC Battery Cartridge Replacement, Remove the front bezel: step 3, image 1 of 3 APC Smart-UPS SMT1500RM2UC Battery Cartridge Replacement, Remove the front bezel: step 3, image 2 of 3 APC Smart-UPS SMT1500RM2UC Battery Cartridge Replacement, Remove the front bezel: step 3, image 3 of 3
    • Gently pull the unclipped edge of the bezel away from the device until the other clip releases.
    • Remove the front bezel.
    • During reassembly, push the bezel into place until both clips engage.
  4. APC Smart-UPS SMT1500RM2UC Battery Cartridge Replacement, Remove the battery disconnect string: step 4, image 1 of 2 APC Smart-UPS SMT1500RM2UC Battery Cartridge Replacement, Remove the battery disconnect string: step 4, image 2 of 2
    • Pull the battery disconnect string out of its recess in the middle of the front edge.
  5. APC Smart-UPS SMT1500RM2UC Battery Cartridge Replacement, Disconnect the battery: step 5, image 1 of 3 APC Smart-UPS SMT1500RM2UC Battery Cartridge Replacement, Disconnect the battery: step 5, image 2 of 3 APC Smart-UPS SMT1500RM2UC Battery Cartridge Replacement, Disconnect the battery: step 5, image 3 of 3
    • Use the battery disconnect string to pull the yellow connector completely out of its socket, disconnecting the battery.
  6. APC Smart-UPS SMT1500RM2UC Battery Cartridge Replacement, Unfasten the battery cartridge: step 6, image 1 of 2 APC Smart-UPS SMT1500RM2UC Battery Cartridge Replacement, Unfasten the battery cartridge: step 6, image 2 of 2
    • Use a Phillips screwdriver to remove the six 11.2 mm‑long screws securing the battery cartridge.
  7. APC Smart-UPS SMT1500RM2UC Battery Cartridge Replacement, Remove the battery cartridge: step 7, image 1 of 2 APC Smart-UPS SMT1500RM2UC Battery Cartridge Replacement, Remove the battery cartridge: step 7, image 2 of 2
    • Slide the battery cartridge out of the device until it stops.
  8. APC Smart-UPS SMT1500RM2UC Battery Cartridge Replacement: step 8, image 1 of 3 APC Smart-UPS SMT1500RM2UC Battery Cartridge Replacement: step 8, image 2 of 3 APC Smart-UPS SMT1500RM2UC Battery Cartridge Replacement: step 8, image 3 of 3
Spencer Day
94,949 Reputation
662 Guides authored
iFixit Member of iFixit
Staff
118 Members
19,453 Guides authored
0 Comments
Past 24 Hours: 5
Past 7 Days: 32
Past 30 Days: 81
All Time: 1,428
