APEX AP-GS918 Battery Replacement
  1. APEX AP-GS918 Battery Replacement, Power/Volume Button: step 1, image 1 of 3 APEX AP-GS918 Battery Replacement, Power/Volume Button: step 1, image 2 of 3 APEX AP-GS918 Battery Replacement, Power/Volume Button: step 1, image 3 of 3
    • To begin, locate the two 4.9mm Phillips #00 screws at the top corners of the case and remove them.
  2. APEX AP-GS918 Battery Replacement: step 2, image 1 of 3 APEX AP-GS918 Battery Replacement: step 2, image 2 of 3 APEX AP-GS918 Battery Replacement: step 2, image 3 of 3
    • Squeeze the plastic opening tool in between the seam where the screen joins the plastic case.
    • Begin separating the bottom of the case from the screen by carefully going around the whole edge of the case and slowly prying it apart.
    • Be careful when separating the lids because the wires holding the speaker to the motherboard are very short.
  3. APEX AP-GS918 Battery Replacement: step 3, image 1 of 2 APEX AP-GS918 Battery Replacement: step 3, image 2 of 2
    Tool used on this step:
    Buy
    • Carefully place the bottom lid next to the screen case. The power/speaker buttons should be visible at the corner of the lid. Remove the buttons with the tweezers.
  4. APEX AP-GS918 Battery Replacement, Battery: step 4, image 1 of 2 APEX AP-GS918 Battery Replacement, Battery: step 4, image 2 of 2
    • Begin removing the black tape covering the motherboard inside the tablet.
  5. APEX AP-GS918 Battery Replacement: step 5, image 1 of 1
    • You will need to desolder the two contact points that connect the battery to the mother board.
    • Make sure to allow ample time (at least 5-8 minutes or more) for the soldering iron to heat up. Otherwise, the solder won't melt.
    • Touch the hot iron to the contact points and gently pull on the wires to loosen them from the solder. They should release easily.
    • Make sure not to touch the contact points after desoldering them because they will remain very hot for a short while afterwards.
  6. APEX AP-GS918 Battery Replacement: step 6, image 1 of 2 APEX AP-GS918 Battery Replacement: step 6, image 2 of 2
    • Using the black nylon spudger, get underneath the battery and begin prying it loose from the rest of the tablet.
    • The tape holding the battery to the tablet has a very strong hold so be prepared for resistance.
2 other people completed this guide.
Megan Lozicki
413 Reputation
4 Guides authored
USF Tampa, Team 9-1, Leahy Winter 2015 Member of USF Tampa, Team 9-1, Leahy Winter 2015
USFT-LEAHY-W15S9G1
3 Members
9 Guides authored
One Comment
bien consejo, creo que es sencillo por todos para seguin estos pasos
harkhoscole - Reply
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 17
All Time: 518
