APEX AP-GS918 Power/Volume Button Replacement
  1. APEX AP-GS918 Power/Volume Button Replacement, Power/Volume Button: step 1, image 1 of 3 APEX AP-GS918 Power/Volume Button Replacement, Power/Volume Button: step 1, image 2 of 3 APEX AP-GS918 Power/Volume Button Replacement, Power/Volume Button: step 1, image 3 of 3
    • To begin, locate the two 4.9mm Phillips #00 screws at the top corners of the case and remove them.
  2. APEX AP-GS918 Power/Volume Button Replacement: step 2, image 1 of 3 APEX AP-GS918 Power/Volume Button Replacement: step 2, image 2 of 3 APEX AP-GS918 Power/Volume Button Replacement: step 2, image 3 of 3
    • Squeeze the plastic opening tool in between the seam where the screen joins the plastic case.
    • Begin separating the bottom of the case from the screen by carefully going around the whole edge of the case and slowly prying it apart.
    • Be careful when separating the lids because the wires holding the speaker to the motherboard are very short.
  3. APEX AP-GS918 Power/Volume Button Replacement: step 3, image 1 of 2 APEX AP-GS918 Power/Volume Button Replacement: step 3, image 2 of 2
    Tool used on this step:
    Buy
    • Carefully place the bottom lid next to the screen case. The power/speaker buttons should be visible at the corner of the lid. Remove the buttons with the tweezers.
Christopher Wright
127 Reputation
1 Guide authored
USF Tampa, Team 9-1, Leahy Winter 2015 Member of USF Tampa, Team 9-1, Leahy Winter 2015
USFT-LEAHY-W15S9G1
3 Members
9 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 8
All Time: 223
