APEX AP-GS918 Speakers Replacement
  1. APEX AP-GS918 Speakers Replacement, Power/Volume Button: step 1, image 1 of 3 APEX AP-GS918 Speakers Replacement, Power/Volume Button: step 1, image 2 of 3 APEX AP-GS918 Speakers Replacement, Power/Volume Button: step 1, image 3 of 3
    • To begin, locate the two 4.9mm Phillips #00 screws at the top corners of the case and remove them.
  2. APEX AP-GS918 Speakers Replacement: step 2, image 1 of 3 APEX AP-GS918 Speakers Replacement: step 2, image 2 of 3 APEX AP-GS918 Speakers Replacement: step 2, image 3 of 3
    • Squeeze the plastic opening tool in between the seam where the screen joins the plastic case.
    • Begin separating the bottom of the case from the screen by carefully going around the whole edge of the case and slowly prying it apart.
    • Be careful when separating the lids because the wires holding the speaker to the motherboard are very short.
  3. APEX AP-GS918 Speakers Replacement: step 3, image 1 of 2 APEX AP-GS918 Speakers Replacement: step 3, image 2 of 2
    Tool used on this step:
    Buy
    • Carefully place the bottom lid next to the screen case. The power/speaker buttons should be visible at the corner of the lid. Remove the buttons with the tweezers.
  4. APEX AP-GS918 Speakers Replacement, Speakers: step 4, image 1 of 3 APEX AP-GS918 Speakers Replacement, Speakers: step 4, image 2 of 3 APEX AP-GS918 Speakers Replacement, Speakers: step 4, image 3 of 3
    • The speaker is attached to the bottom lid with with a small amount of glue and the wires are soldered to the motherboard.
    • In order to remove the speaker you will have to desolder the wires connected to the motherboard.
    • Start by peeling back the black electrical tape covering the motherboard components
    • You will also need to remove the black cloth tape covering the wire contact points.
  5. APEX AP-GS918 Speakers Replacement: step 5, image 1 of 2 APEX AP-GS918 Speakers Replacement: step 5, image 2 of 2
    • Now that the contacts are exposed, you can desolder them.
    • Make sure to allow ample time (at least 5-8 minutes or more) for the soldering iron to heat up. Otherwise, the solder won't melt.
    • Touch the hot iron to the contact points and gently pull on the wires to loosen them from the solder. They should release easily.
    • Make sure not to touch the contact points after desoldering them because they will remain very hot for a short while afterwards.
    • The speaker can now be removed. You may need to pull it with some force since there is a small bead of hot glue holding the speaker to its housing
Megan Lozicki
413 Reputation
4 Guides authored
USF Tampa, Team 9-1, Leahy Winter 2015 Member of USF Tampa, Team 9-1, Leahy Winter 2015
USFT-LEAHY-W15S9G1
3 Members
9 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 11
All Time: 188
