APEX TM785CH Battery Replacement
  1. APEX TM785CH Battery Replacement, Back Casing: step 1, image 1 of 2 APEX TM785CH Battery Replacement, Back Casing: step 1, image 2 of 2
    • Start by bending the tablet back at the top white-colored portion to expose an opening between the back cover and the tablet body.
    • Wedge a plastic opening tool into the opening and push it down to force the back cover off.
    • Move along the top edge of the tablet and repeat the step above.
    • Pull the back cover away from the tablet body to completely remove it.
  2. APEX TM785CH Battery Replacement, Battery: step 2, image 1 of 2 APEX TM785CH Battery Replacement, Battery: step 2, image 2 of 2
    • With the back cover removed, you can now see the battery.
    • You will need a soldering/desoldering kit to desolder the 3 battery leads to the circuit board.
2 other people completed this guide.
Brian Graschel
823 Reputation
6 Guides authored
Baylor, Team 4-1, Williams Spring 2015 Member of Baylor, Team 4-1, Williams Spring 2015
BU-WILLIAMS-S15S4G1
3 Members
12 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 12
All Time: 2,255
