APEX TM785CH Front Camera Replacement
  1. APEX TM785CH Front Camera Replacement, Back Casing: step 1, image 1 of 2 APEX TM785CH Front Camera Replacement, Back Casing: step 1, image 2 of 2
    • Start by bending the tablet back at the top white-colored portion to expose an opening between the back cover and the tablet body.
    • Wedge a plastic opening tool into the opening and push it down to force the back cover off.
    • Move along the top edge of the tablet and repeat the step above.
    • Pull the back cover away from the tablet body to completely remove it.
  2. APEX TM785CH Front Camera Replacement, Front Camera: step 2, image 1 of 2 APEX TM785CH Front Camera Replacement, Front Camera: step 2, image 2 of 2
    • To get to the front camera, you will first need to remove the top panel.
    • Unscrew two 2.25 mm Phillips screws with a #00 screwdriver from the top plastic panel to remove it.
  3. APEX TM785CH Front Camera Replacement: step 3, image 1 of 1
    • Once unscrewed, use a spudger to pop the panel off by wedging it underneath the panel.
  4. APEX TM785CH Front Camera Replacement: step 4, image 1 of 3 APEX TM785CH Front Camera Replacement: step 4, image 2 of 3 APEX TM785CH Front Camera Replacement: step 4, image 3 of 3
    Tool used on this step:
    Buy
    • First, use plastic coated tweezers to pull up the black release tab.
    • Pull on the black connector with tweezers as close as possible to the white connector base, making sure not to pull on the connector base.
    • It is important to be careful not to damage the black connector tape or the white base.
    • Next, use the tweezers to peel off the tape holding down the connector to the front camera.
    • The front camera can now be removed from its socket.
Brian Graschel
823 Reputation
6 Guides authored
Baylor, Team 4-1, Williams Spring 2015 Member of Baylor, Team 4-1, Williams Spring 2015
BU-WILLIAMS-S15S4G1
3 Members
12 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 8
All Time: 334
