APEX TM785CH Microphone Replacement
  1. APEX TM785CH Microphone Replacement, Back Casing: step 1, image 1 of 2 APEX TM785CH Microphone Replacement, Back Casing: step 1, image 2 of 2
    • Start by bending the tablet back at the top white-colored portion to expose an opening between the back cover and the tablet body.
    • Wedge a plastic opening tool into the opening and push it down to force the back cover off.
    • Move along the top edge of the tablet and repeat the step above.
    • Pull the back cover away from the tablet body to completely remove it.
  2. APEX TM785CH Microphone Replacement, Microphone: step 2, image 1 of 3 APEX TM785CH Microphone Replacement, Microphone: step 2, image 2 of 3 APEX TM785CH Microphone Replacement, Microphone: step 2, image 3 of 3
    • The microphone is located in the bottom center of the tablet.
    • Remove the black tape holding the wires down.
    • Remove the black tape holding the microphone in place.
    • The microphone is now exposed and can be gently pulled out of the socket.
  3. APEX TM785CH Microphone Replacement: step 3, image 1 of 1
    • You will need a soldering/desoldering kit to desolder the 2 leads where the microphone connects to the circuit board.
Brian Graschel
823 Reputation
6 Guides authored
Baylor, Team 4-1, Williams Spring 2015 Member of Baylor, Team 4-1, Williams Spring 2015
BU-WILLIAMS-S15S4G1
3 Members
12 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 6
All Time: 272
