APS Tech 101629 SCSI Connections Replacement
  1. APS Tech 101629 SCSI Connections Replacement, External Casing: step 1, image 1 of 3 APS Tech 101629 SCSI Connections Replacement, External Casing: step 1, image 2 of 3 APS Tech 101629 SCSI Connections Replacement, External Casing: step 1, image 3 of 3
    • Pry all four of the plastic feet off the bottom of the enclosure using the iPod opening tool.
  2. APS Tech 101629 SCSI Connections Replacement: step 2, image 1 of 2 APS Tech 101629 SCSI Connections Replacement: step 2, image 2 of 2
    • Unscrew the four screws previously covered by the feet with a Phillips #1 screwdriver.
  3. APS Tech 101629 SCSI Connections Replacement: step 3, image 1 of 2 APS Tech 101629 SCSI Connections Replacement: step 3, image 2 of 2
    • Flip the device right side up.
    • Gently slide the casing upwards and off the hard drive.
  4. APS Tech 101629 SCSI Connections Replacement: step 4, image 1 of 1
    • Flip device upside down again.
    • Gently pry the bottom gray casing away from the device.
  5. APS Tech 101629 SCSI Connections Replacement: step 5, image 1 of 2 APS Tech 101629 SCSI Connections Replacement: step 5, image 2 of 2
    • Rotate so the back of the device is facing you.
    • Gently pry the back casing away.
    • When the back casing is removed, the fan will become loose.
  6. APS Tech 101629 SCSI Connections Replacement, Internal Drive Component: step 6, image 1 of 2 APS Tech 101629 SCSI Connections Replacement, Internal Drive Component: step 6, image 2 of 2
    • Flip so device is upside down.
    • Remove 4 screws with Phillips #1 screw driver.
    • Be sure to save the washers that seperate the screws from the baseplate for reassembly.
  7. APS Tech 101629 SCSI Connections Replacement: step 7, image 1 of 2 APS Tech 101629 SCSI Connections Replacement: step 7, image 2 of 2
    • Slide the internal drive component away from the back of the device.
    • Remove the connections from the back of the internal component in the order of your choosing, we suggest left to right. The connections are:
    • Audio Connection
    • SCSI ID
    • Terminate On
    • SCSI Connection
    • DC Input (power)
  8. APS Tech 101629 SCSI Connections Replacement, SCSI Connections: step 8, image 1 of 3 APS Tech 101629 SCSI Connections Replacement, SCSI Connections: step 8, image 2 of 3 APS Tech 101629 SCSI Connections Replacement, SCSI Connections: step 8, image 3 of 3
    • Remove the four Phillips #1 Screws from back panel.
    • Once the screws are removed, the two connections are easily removed from the body.
Patrick Meyer
83 Reputation
3 Guides authored
Cal Poly, Team 24-60, Amido Spring 2011 Member of Cal Poly, Team 24-60, Amido Spring 2011
CPSU-AMIDO-S11S24G60
5 Members
12 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 11
All Time: 886
