ASUS X540BA-BB61-CB Screen Replacement
  1. ASUS  X540BA-BB61-CB Screen Replacement, Power Down the Laptop: step 1, image 1 of 2 ASUS  X540BA-BB61-CB Screen Replacement, Power Down the Laptop: step 1, image 2 of 2
    • Power off the device and unplug it from the charging cord.
  2. ASUS  X540BA-BB61-CB Screen Replacement, Remove the Bezel Frame: step 2, image 1 of 2 ASUS  X540BA-BB61-CB Screen Replacement, Remove the Bezel Frame: step 2, image 2 of 2
    • Use a spudger to remove the plastic screw covers in the bottom right and left corner of the screen.
    • Remove the two Phillips #2 (M2.5 x4)mm flat head screws in the two bottom corners under the screw covers.
    • Then remove the bezel frame with a spudger.
  3. ASUS  X540BA-BB61-CB Screen Replacement, Remove the Bezel: step 3, image 1 of 1
    • Once these screws are removed, carefully remove the bezel by the inner edge working your way around the perimeter.
    • Be careful to undo the clips as you remove the bezel and don't yank it off. The bezel is flexible but can break.
  4. ASUS  X540BA-BB61-CB Screen Replacement, Remove the grounding tape: step 4, image 1 of 1
    • Remove the grounding tape covering the screws in the four corners of the screen.
    • Use a Phillips #2 screwdriver to remove four (M2 x 4) mm screws from the four corners of the screen that hold the LCD panel in place.
  5. ASUS  X540BA-BB61-CB Screen Replacement, Remove the Screen: step 5, image 1 of 1
    • Peel off one side of the tape and remove the two bottom screws.
    • It is important to remember that the video cable is secured with cleared tape.
    • Peel off the tape, gently slide the cable out and remove the LCD Panel. Take the new LCD panel and place it on the keyboard.
    • Gently slide the connector to the jack secured with cleared tape with both hands.
David Shodipo
1 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 12
Past 30 Days: 69
All Time: 1,158
