ASUS Chromebook C200MA DS01 Touchpad Replacement
  1. ASUS Chromebook C200MA DS01 Touchpad Replacement, Back Panel: step 1, image 1 of 1
    • Before proceeding, power down your Chromebook. Close the display and lay it on a soft surface, top-side down.
    • Remove the five 8.4 mm Phillips #0 screws.
    • Remove the four 4.6 mm Phillips #0 screws.
  2. ASUS Chromebook C200MA DS01 Touchpad Replacement: step 2, image 1 of 1
    • Use the plastic opening tool to gently work around the edge of the Chromebook until the back panel starts to lift off.
  3. ASUS Chromebook C200MA DS01 Touchpad Replacement: step 3, image 1 of 1
    • Remove the back panel by lifting it away from the Chromebook.
    • Some clicking will be heard as the panel is removed from the back, this is completely normal.
  4. ASUS Chromebook C200MA DS01 Touchpad Replacement, Battery Connection: step 4, image 1 of 3 ASUS Chromebook C200MA DS01 Touchpad Replacement, Battery Connection: step 4, image 2 of 3 ASUS Chromebook C200MA DS01 Touchpad Replacement, Battery Connection: step 4, image 3 of 3
    • To disconnect the battery, pinch the multi-color bundle cable with your thumb and forefinger and pull directly back.
  5. ASUS Chromebook C200MA DS01 Touchpad Replacement, Battery: step 5, image 1 of 2 ASUS Chromebook C200MA DS01 Touchpad Replacement, Battery: step 5, image 2 of 2
    • Remove the four 4.7 mm Phillips #0 screws that secure the battery to the Chromebook.
  6. ASUS Chromebook C200MA DS01 Touchpad Replacement: step 6, image 1 of 1
    • Pull out the battery.
  7. ASUS Chromebook C200MA DS01 Touchpad Replacement, Touchpad: step 7, image 1 of 1
    • Locate the touchpad.
    • Locate the touch pad cable connector.
  8. ASUS Chromebook C200MA DS01 Touchpad Replacement: step 8, image 1 of 3 ASUS Chromebook C200MA DS01 Touchpad Replacement: step 8, image 2 of 3 ASUS Chromebook C200MA DS01 Touchpad Replacement: step 8, image 3 of 3
    • Disconnect the touch pad ZIF(zero insertion force) connector.
    • Flip the flap up using a spudger or your fingers.
    • Pull gently on the ribbon cable to disconnect.
  9. ASUS Chromebook C200MA DS01 Touchpad Replacement: step 9, image 1 of 1
    • Gently remove the adhesive on the touch pad ribbon cable.
  10. ASUS Chromebook C200MA DS01 Touchpad Replacement: step 10, image 1 of 3 ASUS Chromebook C200MA DS01 Touchpad Replacement: step 10, image 2 of 3 ASUS Chromebook C200MA DS01 Touchpad Replacement: step 10, image 3 of 3
    • Gently remove the metallic tape from the touch pad only.
    • Try not to tear the tape, it can be re-used during reassembly.
  11. ASUS Chromebook C200MA DS01 Touchpad Replacement: step 11, image 1 of 1
    • Remove the three 1.8 mm Phillips #00 screws.
  12. ASUS Chromebook C200MA DS01 Touchpad Replacement: step 12, image 1 of 2 ASUS Chromebook C200MA DS01 Touchpad Replacement: step 12, image 2 of 2
    • Lift the far edge of the touch pad to remove it.
Christopher Lim
779 Reputation
7 Guides authored
Cal Poly, Team S23-G4, Livingston Spring 2017 Member of Cal Poly, Team S23-G4, Livingston Spring 2017
CPSU-LIVINGSTON-S17S23G4
4 Members
19 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 6
All Time: 610
