ASUS Chromebook C200MA DS01 Wireless Card Replacement
  1. ASUS Chromebook C200MA DS01 Wireless Card Replacement, Back Panel: step 1, image 1 of 1
    • Before proceeding, power down your Chromebook. Close the display and lay it on a soft surface, top-side down.
    • Remove the five 8.4 mm Phillips #0 screws.
    • Remove the four 4.6 mm Phillips #0 screws.
  2. ASUS Chromebook C200MA DS01 Wireless Card Replacement: step 2, image 1 of 1
    • Use the plastic opening tool to gently work around the edge of the Chromebook until the back panel starts to lift off.
  3. ASUS Chromebook C200MA DS01 Wireless Card Replacement: step 3, image 1 of 1
    • Remove the back panel by lifting it away from the Chromebook.
    • Some clicking will be heard as the panel is removed from the back, this is completely normal.
  4. ASUS Chromebook C200MA DS01 Wireless Card Replacement, Battery Connection: step 4, image 1 of 3 ASUS Chromebook C200MA DS01 Wireless Card Replacement, Battery Connection: step 4, image 2 of 3 ASUS Chromebook C200MA DS01 Wireless Card Replacement, Battery Connection: step 4, image 3 of 3
    • To disconnect the battery, pinch the multi-color bundle cable with your thumb and forefinger and pull directly back.
  5. ASUS Chromebook C200MA DS01 Wireless Card Replacement, Wireless Card: step 5, image 1 of 1
    • Remove the silver 2.8 mm Phillips #0 screw from the wireless card.
  6. ASUS Chromebook C200MA DS01 Wireless Card Replacement: step 6, image 1 of 1
    • Use a spudger to disconnect the white and black antenna cables connected to the wireless card.
  7. ASUS Chromebook C200MA DS01 Wireless Card Replacement: step 7, image 1 of 2 ASUS Chromebook C200MA DS01 Wireless Card Replacement: step 7, image 2 of 2
    • Grab the wireless card between your thumb and index finger and pull directly away from the motherboard.
Christopher Lim
779 Reputation
7 Guides authored
Cal Poly, Team S23-G4, Livingston Spring 2017 Member of Cal Poly, Team S23-G4, Livingston Spring 2017
CPSU-LIVINGSTON-S17S23G4
4 Members
19 Guides authored
One Comment
Is this at all possible on Asus 204ma or Asus 214MA ?
Knoll - Reply
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 5
All Time: 805
