ASUS E210MA-TB.CL464BK Wi-Fi Card Replacement
  1. ASUS E210MA-TB.CL464BK Wi-Fi Card Replacement, Wi-Fi Card: step 1, image 1 of 3 ASUS E210MA-TB.CL464BK Wi-Fi Card Replacement, Wi-Fi Card: step 1, image 2 of 3 ASUS E210MA-TB.CL464BK Wi-Fi Card Replacement, Wi-Fi Card: step 1, image 3 of 3
    • Place the laptop with the bottom side facing up. Have the front (where the touchpad is) facing toward you.
    • Start by removing the ten 7mm screws on the bottom of the laptop using a JIS #00 screwdriver.
  2. ASUS E210MA-TB.CL464BK Wi-Fi Card Replacement: step 2, image 1 of 1
    • Double-check to make sure all of the screws are removed.
    • If you have a Jimmy or other flat, straight-edge object, slide it in the crack where the halves of the case meet.
    • When the parts are separated, pull them apart to expose the insides of the case.
  3. ASUS E210MA-TB.CL464BK Wi-Fi Card Replacement: step 3, image 1 of 2 ASUS E210MA-TB.CL464BK Wi-Fi Card Replacement: step 3, image 2 of 2
    • Locate the card and remove it by gently lifting it up and pulling it out.
John Hutchins
763 Reputation
5 Guides authored
Gateway, Team 73-6, Gonzalez Spring 2023 Member of Gateway, Team 73-6, Gonzalez Spring 2023
GCC-GONZALEZ-S23S73G6
5 Members
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 19
All Time: 221
