ASUS Eee PC 1018P Battery Replacement
1 minute
Easy
Better Introduction
Lay the laptop flat on a hard surface with the bottom facing up and the battery pack on the side closest to you.
With the spring tabs pressed inward, use your fingernails to lift of the edge of the battery, pivoting it up and towards you.
Pull the battery pack up and away from you to completely free it from its recess in the case.
