ASUS Eee PC 900HD Clicker Replacement
  1. ASUS Eee PC 900HD Clicker Replacement, Clicker: step 1, image 1 of 3 ASUS Eee PC 900HD Clicker Replacement, Clicker: step 1, image 2 of 3 ASUS Eee PC 900HD Clicker Replacement, Clicker: step 1, image 3 of 3
    • Flip the laptop over and locate the battery lock tabs.
    • Slide the right tab to the unlock position (right) so that the red dot is showing. Then, slide and hold the left tab to its unlock position (left).
    • While holding the left tab to the left, pull the battery out.
  2. ASUS Eee PC 900HD Clicker Replacement: step 2, image 1 of 2 ASUS Eee PC 900HD Clicker Replacement: step 2, image 2 of 2
    • Remove the four 4.76 mm screws using the Phillips J0 Screwdriver.
  3. ASUS Eee PC 900HD Clicker Replacement: step 3, image 1 of 2 ASUS Eee PC 900HD Clicker Replacement: step 3, image 2 of 2
    • Using a plastic opening tool, take off the hard drive cover by lifting it up.
  4. ASUS Eee PC 900HD Clicker Replacement: step 4, image 1 of 3 ASUS Eee PC 900HD Clicker Replacement: step 4, image 2 of 3 ASUS Eee PC 900HD Clicker Replacement: step 4, image 3 of 3
    • Starting from the left, use a plastic opening tool to slide the hard drive all the way to the right.
    • Once the hard drive is all the way to the right, lift it up and pull it out.
  5. ASUS Eee PC 900HD Clicker Replacement: step 5, image 1 of 2 ASUS Eee PC 900HD Clicker Replacement: step 5, image 2 of 2
    • Remove the screw under the hard drive using the Phillips J0 Screwdriver.
  6. ASUS Eee PC 900HD Clicker Replacement: step 6, image 1 of 2 ASUS Eee PC 900HD Clicker Replacement: step 6, image 2 of 2
    Tool used on this step:
    Buy
    • Flip the laptop back over and unlock the three keyboard tabs at the top of the keyboard by pushing down on the silver tabs with tweezers .
  7. ASUS Eee PC 900HD Clicker Replacement: step 7, image 1 of 2 ASUS Eee PC 900HD Clicker Replacement: step 7, image 2 of 2
    • Use the plastic opening tool to lift up the keyboard.
  8. ASUS Eee PC 900HD Clicker Replacement: step 8, image 1 of 3 ASUS Eee PC 900HD Clicker Replacement: step 8, image 2 of 3 ASUS Eee PC 900HD Clicker Replacement: step 8, image 3 of 3
    • Using a pair of tweezers, disconnect the cable at the bottom of the keyboard by flipping the two lock switches up on both sides of the cable.
    • Carefully pull the cable out.
  9. ASUS Eee PC 900HD Clicker Replacement: step 9, image 1 of 3 ASUS Eee PC 900HD Clicker Replacement: step 9, image 2 of 3 ASUS Eee PC 900HD Clicker Replacement: step 9, image 3 of 3
    • Using a pair of tweezers, unlock the touchpad ribbon by pushing the white lock tab to the right.
    • Carefully pull the ribbon to the right.
  10. ASUS Eee PC 900HD Clicker Replacement: step 10, image 1 of 3 ASUS Eee PC 900HD Clicker Replacement: step 10, image 2 of 3 ASUS Eee PC 900HD Clicker Replacement: step 10, image 3 of 3
    • Remove the nine 4.76 mm screws from the top cover of the laptop using the Phillips J0 Screwdriver.
    • Using a plastic opening tool, pry up the edges of the cover.
    • Caution: Be careful around the audio and microphone jacks as they can be easily damaged. Lift the right half of the cover and move it towards the left.
  11. ASUS Eee PC 900HD Clicker Replacement: step 11, image 1 of 2 ASUS Eee PC 900HD Clicker Replacement: step 11, image 2 of 2
    • Lift up and remove the top cover of the laptop.
    • Flip this cover over to reveal the back.
  12. ASUS Eee PC 900HD Clicker Replacement: step 12, image 1 of 3 ASUS Eee PC 900HD Clicker Replacement: step 12, image 2 of 3 ASUS Eee PC 900HD Clicker Replacement: step 12, image 3 of 3
    • Using a Spudger, push down on the green tabs found on both sides.
    • Pull the clicker off of the cover plate.
Kendall Marie Mehlhorn
572 Reputation
5 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 19
All Time: 382
