ASUS Eee Pad Transformer GPS Antenna Replacement
  1. ASUS Eee Pad Transformer GPS Antenna Replacement, Back Panel: step 1, image 1 of 2 ASUS Eee Pad Transformer GPS Antenna Replacement, Back Panel: step 1, image 2 of 2
    • Use T5 Torx Screwdriver to remove two 4.5 millimeter T5 screws on either side of the port on the bottom of the tablet.
  2. ASUS Eee Pad Transformer GPS Antenna Replacement: step 2, image 1 of 3 ASUS Eee Pad Transformer GPS Antenna Replacement: step 2, image 2 of 3 ASUS Eee Pad Transformer GPS Antenna Replacement: step 2, image 3 of 3
    • Use the Plastic Opening Tool to pry between the main tablet body and the outer rim casing. Remove the outer rim casing by prying all the way around the device and pulling the rim upward.
    • The physical buttons are located on the outside of the rim on the right side, proceed with the guide to locate internal buttons.
  3. ASUS Eee Pad Transformer GPS Antenna Replacement: step 3, image 1 of 1
    • Remove the four 2 millimeter Phillips #00 screws at the corners of the tablet.
  4. ASUS Eee Pad Transformer GPS Antenna Replacement: step 4, image 1 of 1
    • Use a Phillips #00 Screwdriver to remove the three 3 millimeter screws securing the front panel to the back panel found above the camera area, on the top portion of the tablet.
  5. ASUS Eee Pad Transformer GPS Antenna Replacement: step 5, image 1 of 1
    • Use a Phillips #00 Screwdriver to remove the three 3 millimeter screws securing the front panel to the back panel found on the bottom portion of the tablet near the port.
  6. ASUS Eee Pad Transformer GPS Antenna Replacement: step 6, image 1 of 2 ASUS Eee Pad Transformer GPS Antenna Replacement: step 6, image 2 of 2
    • Remove back panel by pulling away from the remaining device.
  7. ASUS Eee Pad Transformer GPS Antenna Replacement, GPS Antenna: step 7, image 1 of 3 ASUS Eee Pad Transformer GPS Antenna Replacement, GPS Antenna: step 7, image 2 of 3 ASUS Eee Pad Transformer GPS Antenna Replacement, GPS Antenna: step 7, image 3 of 3
    • Remove the GPS antenna using the spudger.
  8. ASUS Eee Pad Transformer GPS Antenna Replacement: step 8, image 1 of 3 ASUS Eee Pad Transformer GPS Antenna Replacement: step 8, image 2 of 3 ASUS Eee Pad Transformer GPS Antenna Replacement: step 8, image 3 of 3
    Tool used on this step:
    Buy
    • Use a pair of tweezers to disconnect the two wires.
    • Remove the GPS Antenna from the device.
Rillian Dennis
202 Reputation
2 Guides authored
IUPUI, Team S1-G5, Harley Fall 2019 Member of IUPUI, Team S1-G5, Harley Fall 2019
IUPUI-HARLEY-F19S1G5
3 Members
2 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 4
All Time: 165
