ASUS Eee Pad Transformer microSD Card Slot, HDMI Port, and Headphone Jack Replacement
  1. ASUS Eee Pad Transformer microSD Card Slot, HDMI Port, and Headphone Jack Replacement, Back Panel: step 1, image 1 of 2 ASUS Eee Pad Transformer microSD Card Slot, HDMI Port, and Headphone Jack Replacement, Back Panel: step 1, image 2 of 2
    • Use T5 Torx Screwdriver to remove two 4.5 millimeter T5 screws on either side of the port on the bottom of the tablet.
  2. ASUS Eee Pad Transformer microSD Card Slot, HDMI Port, and Headphone Jack Replacement: step 2, image 1 of 3 ASUS Eee Pad Transformer microSD Card Slot, HDMI Port, and Headphone Jack Replacement: step 2, image 2 of 3 ASUS Eee Pad Transformer microSD Card Slot, HDMI Port, and Headphone Jack Replacement: step 2, image 3 of 3
    • Use the Plastic Opening Tool to pry between the main tablet body and the outer rim casing. Remove the outer rim casing by prying all the way around the device and pulling the rim upward.
    • The physical buttons are located on the outside of the rim on the right side, proceed with the guide to locate internal buttons.
  3. ASUS Eee Pad Transformer microSD Card Slot, HDMI Port, and Headphone Jack Replacement: step 3, image 1 of 1
    • Remove the four 2 millimeter Phillips #00 screws at the corners of the tablet.
  4. ASUS Eee Pad Transformer microSD Card Slot, HDMI Port, and Headphone Jack Replacement: step 4, image 1 of 1
    • Use a Phillips #00 Screwdriver to remove the three 3 millimeter screws securing the front panel to the back panel found above the camera area, on the top portion of the tablet.
  5. ASUS Eee Pad Transformer microSD Card Slot, HDMI Port, and Headphone Jack Replacement: step 5, image 1 of 1
    • Use a Phillips #00 Screwdriver to remove the three 3 millimeter screws securing the front panel to the back panel found on the bottom portion of the tablet near the port.
  6. ASUS Eee Pad Transformer microSD Card Slot, HDMI Port, and Headphone Jack Replacement: step 6, image 1 of 2 ASUS Eee Pad Transformer microSD Card Slot, HDMI Port, and Headphone Jack Replacement: step 6, image 2 of 2
    • Remove back panel by pulling away from the remaining device.
  7. ASUS Eee Pad Transformer microSD Card Slot, HDMI Port, and Headphone Jack Replacement, Remove screws: step 7, image 1 of 1
    • Use a Phillips #00 Screwdriver to remove the three 3 millimeter screws found on back side of the device to the left of the rear-facing camera.
  8. ASUS Eee Pad Transformer microSD Card Slot, HDMI Port, and Headphone Jack Replacement, Lift up flaps: step 8, image 1 of 2 ASUS Eee Pad Transformer microSD Card Slot, HDMI Port, and Headphone Jack Replacement, Lift up flaps: step 8, image 2 of 2
    • Use Plastic Opening Tool to lift up the two white flaps.
  9. ASUS Eee Pad Transformer microSD Card Slot, HDMI Port, and Headphone Jack Replacement, Remove wire clip: step 9, image 1 of 2 ASUS Eee Pad Transformer microSD Card Slot, HDMI Port, and Headphone Jack Replacement, Remove wire clip: step 9, image 2 of 2
    Tool used on this step:
    Buy
    • Use Tweezers to unclip the wire from the back panel by pulling straight outward from the device.
  10. ASUS Eee Pad Transformer microSD Card Slot, HDMI Port, and Headphone Jack Replacement, Pull out panel: step 10, image 1 of 3 ASUS Eee Pad Transformer microSD Card Slot, HDMI Port, and Headphone Jack Replacement, Pull out panel: step 10, image 2 of 3 ASUS Eee Pad Transformer microSD Card Slot, HDMI Port, and Headphone Jack Replacement, Pull out panel: step 10, image 3 of 3
    • Pull microSD Card, HDMI Port, and Headphone Jack panel straight out from tablet.
    • Use Plastic Opening Tool to remove the wire on the panel by hooking it around the white clip and pulling straight out from the panel.
4 other people completed this guide.
Sandy Babich
1,885 Reputation
5 Guides authored
Cal Poly, Team 13-9, Forte Fall 2014 Member of Cal Poly, Team 13-9, Forte Fall 2014
CPSU-FORTE-F14S13G9
5 Members
12 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 6
All Time: 3,897
